Trans Am Gauge Bezel with Gauge pods *Finished Pics*
Old 11-03-2011, 06:03 PM
djfury05's Avatar
looks great
Old 03-27-2012, 08:21 PM
14k
14k's Avatar
How do you route the wires for the gauge? Through the lap panel? Or some other way?
Old 03-27-2012, 10:37 PM
olskoolLT1's Avatar
that looks damn good
Old 03-28-2012, 02:08 AM
Swiat34's Avatar
The lap panel is probably the best way. It's like routing wires for any aftermarket ****, gotta be creative. I don't even use this in my T/A since it's a project and in pieces. I don't yet have the gauges I need even. I offer this one for sale just because I know others can put it to good use right away. Thanks for the compliments guys! I'll be working on one for Camaros too so stay tuned!
Old 03-28-2012, 08:50 AM
CamaroSS27's Avatar
wow great job!
Old 03-28-2012, 10:32 AM
14k
14k's Avatar
I'm definitely interested in a camaro one
Old 03-29-2012, 06:41 AM
cancam99ss's Avatar
LS1Tech 10 Year
I'm in for a Camaro ione
Old 03-31-2012, 01:08 AM
14k
14k's Avatar
any update on the 'camaro version?
Old 03-31-2012, 07:12 AM
ta-stanger's Avatar
Looks sweet!!
Old 03-31-2012, 03:29 PM
Swiat34's Avatar
Got a rough-in for the Camaro but my Z28 friend hasn't been by so I can test fit.
Old 03-31-2012, 05:04 PM
WS.SIX's Avatar
are you going to start producing these for T/A's and Camaros or is it just a one time thing?
Old 03-31-2012, 07:39 PM
  #32
Swiat34's Avatar
I make em to order.
Old 03-31-2012, 09:18 PM
  #33
98 WS6's Avatar
Nice work dude! Once I have my dream T/A again I'll be putting gauges right back in the vents, that's my favorite so far.
Old 06-16-2017, 11:33 AM
  #34
Phoenix'97's Avatar
Post
Originally Posted by Swiat34
So I had a bit of a brain storm thinking about how much I don't like the look of pillar pods and came up with this. I used 2" PVC and borrowed an old Trans Temp gauge from a friend for test fitting. After deciding on placement, I cut the bezel and PVC then used JBStick epoxy to keep it in place. It's a VERY strong bond! I used my dremel to grind away the excess epoxy before contouring with a lightweight body filler. I shaped it by hand sanding. It got a coat of Spotting and Glazing putty to fill small imperfections. I sanded over the entire bezel to eliminate the factory texture before getting the coat of sandable primer. That'll get wet sanded and finally coated with a Dupont Semi-gloss black. So here's the pics!
I am going to have to remember this post in a few years. I have the pillar gauge pod set-up right now, and after experiencing how much more difficult it is to clean my windshield near that area and to apply new registration and inspection stickers, I would much rather have my factory pillar trim back.
I will be in the market for a single pod in the upper left portion of the gauge bezel, something that allows me to watch both my factory tachometer and the vacuum gauge that will be installed in that pod, without blocking the view of the warning indicators in that same upper left corner of the gauge cluster.
I have seen this desired set-up being offered online, but it's a dual pod version, I really wish to cease use of my second physical oil pressure gauge.
Old 06-21-2017, 10:31 PM
  #35
Tipnitty's Avatar
Pretty sweet. I had one of these in my DD honda, but I couldn't read them very well. Thought about trying to make something similar, but I have far too many projects on hand. Good work!
Old 06-22-2017, 07:42 AM
  #36
CoreyD's Avatar
LS1Tech 10 Year
Nice work!
Old 06-27-2017, 10:57 PM
  #37
Firebirdmuscle's Avatar
LS1Tech 10 Year
That looks very good. Definitely like this better than an a pillar setup even tho I have a triple pod one. Great job.
Quick Reply: Trans Am Gauge Bezel with Gauge pods *Finished Pics*
