Aftermarket steering wheels?
Old Mar 14, 2004 | 10:22 PM
02Z28's Avatar
Default Aftermarket steering wheels?
Does anyone know where I can get a aftermarket steering wheel for my 02 camaro I looked on the grant site and it said their steering wheels won't fit a airbag steering column.
Old Mar 15, 2004 | 09:57 AM
SilverGhost's Avatar
Motorboater
I have a grant on mine, just a random simple black one i got from i think Autozone.
you just have to get the right adapter kit, i'll save you a shitload of time and money by telling you its the one for the newest GMC truck, late 80-early 90's or soemthing i forget.
Old Mar 16, 2004 | 07:57 PM
02Z28's Avatar
Does anyone know why it wouldn't fit? I don't want airbags so I am going to take them out and put in a steering wheel that I could use to activate my nitrous.
Old Mar 17, 2004 | 11:05 PM
Cal's Avatar
Cal
I just installed a Grant "signature series" wheel from Checker Auto parts. They don't sell an adapter kit for any car with an air bag, probably because they don't want to be sued for you removing the air bag. I decided to try their "GM Billet" kit #5196-1, and it worked out great. The only special thing I did was machine about 40 thousandths off the bell so it doesn't rub on the steering column. You could also just grind it down a bit if you don't want to lathe cut it.
Old Mar 17, 2004 | 11:17 PM
jaljohn's Avatar
see, the problem with aftermarket steering wheels is if you put in a steering wheel to replace one that previously did, the airbag light will stay on. this can be fixed if you find the amount of resistance the actual airbag unit had in it. if you find this, you can just add a resitor and the light will go off because the vehicle's computer thinks there is an airbag.
Old Mar 18, 2004 | 09:20 AM
Cal's Avatar
Cal
Yes, I used a 2 ohm resister, and this is the value others have used as well. I just clipped the leads short and soldered it accross the yellow and black wires. Presto, no more airbag light.
Old Mar 18, 2004 | 04:05 PM
NataSS Inc's Avatar
I am using the sparco 368 on a quick disconnect.
http://www.sparco-usa.com/psteering_comp.asp?id=135
Old Mar 18, 2004 | 04:46 PM
02Z28's Avatar
do you think a Grant Evoulution GT steering wheel would work? part # 1182 its on the grant website
Old Mar 18, 2004 | 08:49 PM
Big Mike's Avatar
I have a Billet Specialties "Alien" steering wheel. I love it, I get so many compliments on it. It has that "Badd ***" attitude look.
Old Mar 18, 2004 | 09:49 PM
InvisibleSun's Avatar
I went with a Sparco Ring wheel with the 2 button add-on and the quick release:
http://www.sparco-usa.com/psteering_comp.asp?id=160
Old Mar 18, 2004 | 10:37 PM
Cal's Avatar
Cal
Yeah the Evolution wheel is from the signature series, so it will fit just like mine did with the GM Billet" kit #5196-1.
Old Mar 20, 2004 | 01:43 PM
02Z28's Avatar
cool thanks for help guys
Justin
Old Mar 20, 2004 | 02:04 PM
02Z28's Avatar
Did the installation kit come with a horn kit too? If it doesn't what kit would I have to buy to get the horn to work?
Old Mar 20, 2004 | 09:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
People I have heard use a 3rd gen install kit.
Big Mike, where is the button for trans brake I was going to put mine into a steering wheel.
Old Mar 20, 2004 | 09:27 PM
Cal's Avatar
Cal
Yes, mine included everything I needed. I used the stock horn wire and wiper though, rather than the one included in the kit.
Old Mar 20, 2004 | 10:06 PM
Big Mike's Avatar
John, you can't see from the picture, but it's right on top of the B&M shifter.
