Engine Bay Cleanup
Old Feb 4, 2012 | 06:58 PM
autogeek23's Avatar
Originally Posted by jaxcam02
maybe power wash if you cover everything besides the block but I wouldnt use something with high pressure, possibility to rip a wire loose from something probably not likely but i wouldnt risk it, its best to just use a sponge or rag and soapy solution and rinse with hose and dry with a towel.
ok thanks man. cant wait for spring.
Old Feb 4, 2012 | 09:11 PM
justin hover's Avatar
Originally Posted by djfury05
Do not get colored wire loom.. that **** is for ricers and looks dumb as ****
Why not...black on black under the hood is dull enough, let alone all the wires covered in dusty black loom. I swaped mine out with red and I think it looks alot better with my whole color sceme of course...No ricer here, if it's done right and you complete the project of loom it looks good, leave alittle out to where it's noticable you didn't loom it...you got a ricer.
Old Feb 5, 2012 | 06:28 PM
mpatton's Avatar
Tuck all wires on both sides and anything else you can. I just recently started while im waiting for a new motor.
Old Feb 5, 2012 | 06:39 PM
cancam99ss's Avatar
i need to do this....
Old Feb 29, 2024 | 09:42 PM
Need4Camaro's Avatar
I know this topic is old but how and where do you tuck the wires? Any issue with getting it to the PCM? Do you have to heat shield them if you tuck them?
Old Mar 1, 2024 | 04:08 PM
rwb's Avatar
rwb
Wire Mod.
https://ls1tech.com/forums/appearanc...al-inside.html
