Changing Guage Faces?
Old Mar 30, 2004 | 07:07 PM
01 Red WS6's Avatar
Originally Posted by franny40
I ordered mine from Macewen, the install was easy, the only problem i have had is that the oil pressure guage has acted erratically since the install. other than that I love the way it looks
I doubt that it was from the install, Id check the connection in the dash there may be some trash up in the plug, or it may not be in there all the way.
Old Mar 30, 2004 | 07:30 PM
The Kiss Guy's Avatar
My oil gauge did something similar for awhile. At first, with the key off the needle on the oil pressure would stay halfway up. However when I turned the key on or started it, it would go back down or to the actual reading. Now she works normal.
Old Mar 31, 2004 | 09:27 AM
BackInBlack's Avatar
I also did not remove the needles when I installed my gauges.. thought it was too risky being as fragile as they seem.. i slide everything on while all the needles were pointing in one direction thanks to helping hand... But that way you guarantee u dont mess those up
