Painting interior parts
Old 03-28-2004, 10:43 PM
01 Red WS6's Avatar
Question Painting interior parts
I was just wondering what prep work is needed to paint some parts on my interior. Like what do I need to do to get the armor all off and to smooth the parts out. Also what paint do I need to use and do I need to put anything on to make the paint bond to the plastic. What will I need to do to keep it from chipping off.
Thanks
Old 03-29-2004, 05:58 AM
SSZSLP's Avatar
Have any prior painting experience?
Old 03-29-2004, 08:51 AM
Copy & Paste Moderator
VIP1's Avatar
LS1Tech 20 Year Member
Do a search and you'll find a wealth of information.
Here are a few links i found when I used your thread title as the search parameter:
https://ls1tech.com/forums/showthrea...interior+parts
--VIP1
Old 03-29-2004, 09:32 PM
01 Red WS6's Avatar
Some but not much.
01 Red WS6's Avatar
--VIP1
Thanks for the leads
Old 03-30-2004, 10:00 AM
HOSS's Avatar
sand them with 600 grit first, then go to 800 grit, wipe it all down with a wet cloth, let dry, use a primer thats made for stuff like this, then do 5 or 6 light coats of the color u want, again, using a good paint, then if u want it to shine a little more, and have an extra protectant, clear coat it 2 or 3 times...thats how i did mine,been that way for about 5 months, no chips and no fading
Old 03-30-2004, 10:21 AM
Motorboater
SilverGhost's Avatar
I belive its Rustoleum that makes a spray can plastic primer meant for priming plastic obviously..i've used it with success several times on various things..Home Depot has it.
Old 03-30-2004, 03:25 PM
VIP1's Avatar
Krylon has a paint line called "Fusion" that is meant for plastics. I have no experience with is though.
Here is a link I found in a search:
https://ls1tech.com/forums/showthrea...=krylon+fusion
--VIP1
Old 03-31-2004, 07:32 AM
SSZSLP's Avatar
Originally Posted by 01 Red WS6
Some but not much.
I would say that your best bet would be remove the parts and take them to a shop in your area to have them done,cause by the time you buy the "right" materials to do it yourself and end up with questionable results(longetivity wise)you could have paid to have them done
Old 03-31-2004, 09:55 AM
01 Red WS6's Avatar
Ok one last question, What color should I paint my parts?
Ive thought about red to match the car or just going with a dark gray almost black color
Quick Reply: Painting interior parts
