headlights always on
Old Mar 14, 2012 | 09:51 AM
purple98haz28's Avatar
Default headlights always on
My headlights are now always coming on when i put down my ebrake even if it is light out. it did not used to do this...what is wrong
Old Mar 14, 2012 | 10:38 AM
Nathan C's Avatar
I think Camaros have a little sensor on the dash. I may be wording this wrong, but when it is dark out the sensor automatically turns on the lights. Your sensor could be messed up, covered up somehow, or just dirty.
Old Mar 14, 2012 | 02:04 PM
where might i find this sensor to make sure its clean and to test it? thanks-Brandon
Old Mar 14, 2012 | 11:29 PM
14k's Avatar
14k
this! plus my brake light doesn light up anymore either.
Old Mar 15, 2012 | 12:31 AM
Super-Bat's Avatar
Sensor should be under the dashpad I believe. Someone with a Camaro can confirm.
This will help:
http://xse.com/leres/ss/drl.html
Old Mar 15, 2012 | 10:06 AM
14k's Avatar
14k
I think I'm gunna do this. I hate when mine come on and it's bright as hell outside.
Old Mar 15, 2012 | 10:07 AM
14k's Avatar
14k
Op does your brake light come on when you pull th ebrake up?
Old Mar 15, 2012 | 10:40 AM
Super-Bat's Avatar
It shouldnt.
Old Mar 15, 2012 | 10:58 AM
themealonwheels's Avatar
In your case, I'd bet the contact for the ebrake sensor is not contacting the lever. Only thing to do is get in your center console to adjust the little contact to touch when the ebrake is up. I had this problem, adjusting the contact did the trick. You'll see what I'm talking about when you look.
This will help:
The sensor is right next to your alarm light in the middle of the dash pad on the passenger side. If you're very careful, you can gently pry up the front of the pad to access the sensor from below. It's twist-locked in place, you have to twist it back underneath the pad to release it.
It shouldnt.
The hell? You must have misunderstood, I think he meant the BRAKE light on the dash. Yes it most certainly SHOULD indicate when the ebrake is engaged! That's what that light means, BRAKE means your ebrake is at least one notch up!
Old Mar 15, 2012 | 01:20 PM
Super-Bat's Avatar
Oh ya, dash light should come on. I was thinking rear brake lights.
Old Mar 15, 2012 | 02:08 PM
aquariussuperman's Avatar
You can also unplug the DRL/Auto headlights to make you have complete control over when they come on. I unplugged the harness behind the radio as shown in the link several posts up. It's seems more convenient to have control when they turn off. Good luck!
Old Mar 16, 2012 | 03:12 PM
VIP1's Avatar
Copy & Paste Moderator
A better solution to disable the auto-lights is to short together the two wires that go to the light sensor. A simple crimp connector like a scotch-lock works well for that.
