black halos installed...need some help
Old Mar 26, 2004 | 11:24 AM
slik98z's Avatar
Default black halos installed...need some help
before installing the new headlights i ran a bead of silicone around the outside edge and my dumbass missed a spot and i got a little moisture inside the passenger head light. how do i go about to evaporate the moisture so i can put moer silicone on it where i missed it? the headlights have drain plugs and what have you but it seems like not enough air? is getting in to evaporate the moisture. can i put a blow dryer against one of those holes without damaging the headlight?
thanks fellas...just need some ideas.
Travis
Old Mar 26, 2004 | 01:08 PM
Nine Ball's Avatar
LS1Tech Co-Founder
just drive around with the headlights on, the heat from the bulb will help make the condensation evaportate out of the vent hole.
Old Mar 26, 2004 | 01:18 PM
slik98z's Avatar
i was going to do that but the car is apart right now...no hood, fenders front bumper cover is geting painted...while the car was apart i was going to try to do something about it. perhaps ill just put a fan on it and turn the car/lights on for a little bit see if that works, thanks nineball
T
Old Mar 26, 2004 | 03:20 PM
Stew w/92&00's Avatar
take those rubber elbows off the back and they will open up the holes.Mine were condensating and that took care of mine.
