Marker light removal. Haha
Old May 1, 2012 | 08:25 PM
95LTXZ28's Avatar
Default Marker light removal. Haha
Ok tonight I received my clear maker lights and figured I would go out and toss them in. I took out the two screws and the light is loose but I cannot figure out how to get it out of the like bracket or whatever it mounts to. I played around with the driver side for about 20 minutes, then had to get ready to go to work but can someone give me like a dumbed down 5 year old version of the instructions to remove these??? I am trying to access them from the top which is easy for me ( small hands) I even changed my foglight bulbs from up top. But yeah some instructions or pictures would be great. Haha I feel like a huge dumb@$$
Old May 1, 2012 | 10:12 PM
UnVMySS's Avatar
LoL you have to raise the smaller side up and sort of force it around the parts that get in the way. It sounds bad but I've done it multiple times and could do the entire swap in 15 minutes now lol
Old May 1, 2012 | 11:56 PM
95LTXZ28's Avatar
Haha ok buddy thanks alot. I'll give it another try in the morning.
Old May 3, 2012 | 12:02 AM
9WhiteCamaro9's Avatar
Best way I've learned was to take the headlight's out that way you can just reach down and take the corner lights out without anything in the way for you to possibly break or damage. Works for me though.
Old May 3, 2012 | 04:09 AM
95LTXZ28's Avatar
Well I tried for like two minutes today and still no luck. Haha I'm gonna pull it over my pit tomorrow and see how it looks underneath. It seems like it'll be easier to get to that way.
Old May 3, 2012 | 08:15 AM
UnVMySS's Avatar
Nooooo, not easier lmao... Do as whitecamaro said too. I assumed you had the headlights out. Seriously dude you gotta sorta force it.
Old May 3, 2012 | 11:42 AM
The Mighty Texan's Avatar
Yeah take the headlights off and your golden, and like Unv said you do gotta force it a bit, but no worries it won't break or anything.
Old May 3, 2012 | 07:55 PM
Yeah you take the headlights out and you can see 3/4 of the corner light cause of the front, side and back. Just take and pick up on the very outside part of the corner light and kinda tug on it while picking up on the outside corner.
Old May 3, 2012 | 08:42 PM
DaRReLL's Avatar
You really have to put some force to pop it in place.
Old May 4, 2012 | 11:04 AM
78_elky's Avatar
Did you check for the screw on the bottom of the housing? I don't want to offend but I am pretty sure there are 3 screws holding those in. I never put the bottom one back in my car because it was a pain but it was there originally. Oh and like everyone said take the headlights out, it'll be much easier. You'll be able to get the lenses loose with the headlights in but getting them out from where they are is really tricky with the headlights taking up so much space.
Jessica
Old May 4, 2012 | 11:09 AM
^ There's only two in the corner lights and there in the back of the housing itself. If there where three and one went through the bottom, it would come straight up through the light itself.
The problem the OP is running into is having to force them out so he can put in his new ones.
Old May 4, 2012 | 09:34 PM
78_elky's Avatar
Hey,
I don't mind being wrong...but I'm not, there are three screws holding them in I've got a pic. I know for a fact they don't need the bottom screw so maybe yours was missing. Either way I'd say this guy needs to get the headlights out to get the marker lights out easy.
Jessica
Old May 4, 2012 | 10:02 PM
UnVMySS's Avatar
Yes jess is correct. There are 3 screws. Whitecamaro, perhaps you were missing one when you bought your car?
Old May 4, 2012 | 10:22 PM
fucter's Avatar
See, I only have two.... but that's because like years ago, I never put the third one back in.
Old May 4, 2012 | 11:38 PM
zbugger's Avatar
I put mine in from the bottom. You do have to force it a little bit. First time they took an hour. Last time it only took 20 minutes.
Old May 5, 2012 | 02:19 PM
I apologize but y'all might be right. I only took out two and never thought to actually look at the lights themselves to see and when I put my new ones in, I only put in the back two and never had a problem with them sense.
I plan on going back to the factory housings any way after I can get the stuff to clean the stockers up so I'll be sure to check that out when I do and if mine isn't some freak accident and was only came with two holes and I just over looked the third one, I may put all three back in just for extra comfort, .
Old May 5, 2012 | 02:38 PM
78_elky's Avatar
Yeah those are my black clear lenses not on the car...as you can (maybe) see in the blurry pic there is a screw in it still I didn't install them back with 3 it was too much of a pain.
Jess
Old May 5, 2012 | 06:17 PM
95LTXZ28's Avatar
Ok I finally got them out the other day. They were pretty hard coming out but nonetheless they are out and the new ones are in. It seemed the clear ones went in alot easier then the old ones. Thanks for the help though guys.
Old May 5, 2012 | 06:19 PM
95LTXZ28's Avatar
Here are a few pictures of them in.
Old May 5, 2012 | 07:44 PM
UnVMySS's Avatar
Looks good!
