What to use to reseal my t-top and trunk trim?
I've checked my t-tops several times and can't find where they're leaking. They look fine. The only place I can figure that water is getting in is between the seals and the body itself. The seal around the t-tops and the trunk have gotten loose.
What did you guys use to seal the t-tops and trunk? What brand sealant? I'm going to do everything at once. Just take the seals off, put some sealant down, and put them back. Hopefully that will fix the problem.
i had all weatherstripping off my car and i resealed with 3m Black Super Weatherstrip.works great and easy to use..here link: http://www.shop3m.com/60455055602.ht...strip-Adhesive
