What are these spots?
I've tried adjusting the softener settings (cranking it way up, way down, recycling) but I always get these spots. Even worse, if I dry, and leave the most minuscule amount of water spread out (like on the windshield) it leaves this white film which I can draw lines in with my fingers. With detail spray and/or glass cleaner for the windows - it comes right off.
Does anyone have any ideas of what this might be?
Water Spots 1
Water Spots 2
I guess other than that, I'm no help since I wouldn't put much thought into it and it being something that can be took care of with some simple Spray Detail.
If this is the case, I may have to get a spotless water finisher, which aren't cheap!
Doing this as soon as you blow the car off, using some detail spray will be a lot cheaper than one of the filtration systems. You guys might know of a cheaper one, but the ones I have seen were 3-600 bucks for the lowest end ones. With a nice one being around $1500!!
They do make those conditioners that you can add to your wash bucket, but I have no experience with them. Doesn't seem to work to me as it's the rinse water that is leaving the mineral deposits.
Make sure your blowing out all the lights, mirrors, and cracks. They will just run out later leaving a run line. Then dry with the detail spray like I said.
I doubt you have to worry about this since you said you do it in the garage but the paint being cool to the touch and out of the sun light is also a biggy.
They do make those conditioners that you can add to your wash bucket, but I have no experience with them. Doesn't seem to work to me as it's the rinsIe water that is leaving the mineral deposits.
