The Proper Cleaning of the LSx engine bay..
Before
After
Water can (and probably will) get UNDER the intake manifold. The knock sensors are located there and sit in pockets. When water gets in those pockets it has NO PLACE to go except to evaporate. If it doesn't evaporate it will destroy the knock sensors.
If you have a bad knock sensor do a search for the GM TSB on a sort of "fix" for the water problem. If you need any more info on this, PM me and I'll be glad to share (I have pictures, too).
Other than that, cleaning the engine bay is a snap.
I will say keep simple green AWAY... far far away!! from your fuse box covers. That stuff will eat the stickers right off the top and then you can't tell what it was. My bottle leaked a little on top of the cover and when I use a towel to DAB it up, not wipe, just blotted, it took the paint with it. And you can't buy just the sticker from GM, you have to buy a whole new lid!!
So its time for a sticky.. So contribute USEFULL info to the thread.. tips, tricks and such.. posts that dont contribute to the topic will be pruned
What I do..
Remove any parts like FRC's and billet caps, etc (optional)
lightly mist greasy or dirty areas with Simple Green
Loosen heavy areas with a soft bristle brush (toothbrush?)
wash painted areas with car shampoo solution
Rinse with hose
NOTE: Just use common sense.. dont spray high pressure on the MAF, Lid, Coils, PCM and other area.. just rinse them.. DO use high pressure to rinse the block and areas where its obvious water wont do an harm.
I would also (on my engine) pour a gallon or tow of distilled water over the whole deal.. this help with spots on my chromed and polished parts.. but thats just me
Regular guy finish off: Towel dry.. run engine and they towel dry again.. detail to your heart desire...
Advanced finish off: 200mph leaf blower! .. blow that sucker dry and save a lot of time with the towel.. then use compressed air to get all the nooks and crannies dry.. towel off the last drops and detail..
Keep in mind that the engines are designed to be pretty water proof.. we do not have the problems with the Opti that the LT1's had.. just use common sense and remember that even if your not into show, a clean engine is just easier to work on..
Chevy's never need to worked unlike those others that are named after some animal..........LOL
That sucks.
Glad I have a daily driver so I don't have to drive my vette in the rain.
I had one of my new joes spit chew on the side of my car one day.... oh yes had to put some corrective training into play. Just a little cleaning
Now about the knock sensors, I just ran it for two hours afterwards, I really don't think any standing water was left.
I've always found one very handy.
