LED lighting for front license plate emblem on 01 WS6
I don't have a how to do have pics of this and that but believe there is writeup up for lighted rear center section and did mine somewhat similar.Used decal to paint black and was going to use red but chrome gives "hall" effect which you can kinda see but when up close. I trenched in my plexi panel and didn't need keyhole (have remote and button to pop and in progress of hooking up cable pull that has levers for fuel door(whole nother mod,mine has no thumb bump) and hatch.Also used led strips and cluster from shelf at auto store. I will try to get writeup on hood lights the hardest part was hiding the 2 wires which run in gaps on hood edges and lights are led trailer markers mounted in holes from taking out hood baffles.Hope you don't mind better pic of bay put lots of work into so... Really need to get me a BUILD thread getting off subject of this thread.Let me know if more info?
Had to bend with heat gun then trim to fit.Took like 4-5 pieces before got one that I was happy with then used plastic weld epoxy.All kinds of "detail" smoothed/painted fenderwell seams,wiper cowl etc. and made cover for wiper fluid area in front of radiator also fuel/nitrous gauge pod on cowl.moved battery and wires ......
