brighter dash gauges
If you have a Camaro color becomes an issue. A white led behind the stock gauge face makes a aqua type blue, nearly identical to the 2010-2015 Camaros. This is due to the blue film applied to the back of the gauge face, the yellowish light from the incandescent bulb passing thru the blue film makes the white'ish color.
If you want to keep it white, you will need to remove the blue film. Not to worry though as its not hard to do.
Heres your starting point
I saturate only the areas I want to remove with goo gone
Then use an exacto to scrape away the adhesive over the areas you want to remove color
The sand off the color film
All done
