6LE A4 Shifter Overlay
Old Dec 3, 2012 | 05:21 PM
DaRReLL's Avatar
Default 6LE A4 Shifter Overlay
I love the overlay, but it's difficult to see which gear your in. I know a LOT of people have installed them. Is it difficult to see what gear your in when the lever is shifted? It appears that the spot where it should be clear is white on mine, which makes it impossible to see the shift selector underneath. Does everyone else's has color in the spot where it should be clear?
I know that you can just line it up off to the gears with estimation. Has anybody cut a litle hole in the overlay which woulod make it easier to see the shift selector underneath?
Old Dec 3, 2012 | 06:06 PM
crimson_bird's Avatar
the light doesn't illuminate the gear you're in like the stock one?
Old Dec 3, 2012 | 06:27 PM
DaRReLL's Avatar
You can just BARELY see it at night with the lights on.
Impossible to see it during the day. I was thinking a small diameter leather punch to pop a hole through it on each of the gear selections.
Old Dec 4, 2012 | 01:17 AM
Trans.Am98's Avatar
picssss
Old Dec 4, 2012 | 02:49 AM
Pewter T/A 2000's Avatar
No "window" to see the gear selector on mine either. I don't believe any of them do. And I have a boot on mine, so it's even harder to see which number it aligns with. Oh well, just part of it. "One of those things..."
Old Dec 4, 2012 | 10:04 AM
DaRReLL's Avatar
I'll pop some pics tonight...
Old Dec 4, 2012 | 02:40 PM
Sommer86's Avatar
Mine is the same way. It's white, not clear. But you can see the orange indicator at night when it's lit up. I'm also using an LED in there.
Old Dec 4, 2012 | 06:38 PM
DaRReLL's Avatar
Is there a way to format that area to be clear?
I'll by another one if so.....
Old Dec 4, 2012 | 08:06 PM
Sommer86's Avatar
There isn't. I've asked. We use a "clear" plastic to print on, which is that milky color you see. They dont sell the material completely transparent. But I know what you mean. Sorry... But with my install kit, you'd be able to punch the hole and still keep dust out of it.
It's a thought...
Old Dec 5, 2012 | 07:32 AM
DaRReLL's Avatar
Dang it...
That's what I'm going to do, pop a small hole in it
I still love it though, great product!!
Old Dec 5, 2012 | 11:52 AM
Sommer86's Avatar
Dang it...
If you look really, really carefully, you'll see that the white dot have a silver or grey outline to them. I think it would look good if you were able to get the white part punched out perfectly and leave the silver circle.
Also, I'm not sure you should used a leather punch or hole punch. Those stress the materials they're punching and might "pull" the surrounding material and wrinkle it. Maybe a leather punch might be best since i tink the edges are thinner for cutting. Let me know how it works out.
Old Dec 6, 2012 | 12:19 AM
Redbirds's Avatar
Holy cow. I didn't even know that the shifter had a light in it. Mine must have been out before I bought the car- I've always been just feeling for the gear at night
I figured it must have had one. Any idea how hard it is to replace the bulb(s)?
Old Dec 6, 2012 | 01:04 AM
6LITEREATER's Avatar
Super easy. Couple bolts the console piece pops up then the socket just twists out, bulb pulls straight out.
Old Dec 6, 2012 | 11:41 AM
DaRReLL's Avatar
I'll keep ereryone updated....
Old Dec 7, 2012 | 11:21 PM
99'CajunFirehawk157's Avatar
Thumbs up
I was thinking a small diameter leather punch (or single hole punch for paper works too) to pop a hole through it on each of the gear selections.
EXACTLY what I did to mine, one tip; use a straight edge to guide the punch so all holes are lined up straight, don't free hand like I did, mine works great!
Old Dec 10, 2012 | 03:25 AM
Sommer86's Avatar
Here's mine, btw... And mine has my A4 kit installed with 1 LED.
Old Dec 10, 2012 | 09:12 AM
DaRReLL's Avatar
I also noticed i need to move the double sided tape down about a 1/4". I'm going to do the "TRIAL" punch in that area. You have to love Harbor Frieght!!!
