clear bumper warning light install help!
Old Dec 25, 2012 | 11:45 AM
GHall8788's Avatar
Exclamation clear bumper warning light install help!
i have clear warning lights for my front bumper on an 02 camaro, how do you uninstall/ install the new lights, any help appreciated thanks!
Old Dec 25, 2012 | 01:34 PM
buellxb12s's Avatar
Take headlights out with the one 10mm bolt then the 3 7 mm bolts holding the corner in. Pull it out and reversethe order.
Old Dec 25, 2012 | 01:37 PM
nomasterase's Avatar
disconnect the headlight plugs and remove the headlight assemblies first to give yourself some room to work. its just one 10 mm bolt per headlight and then they slide towards the center of the car to release from the core support. there are 3 7mm bolts holding the lens in the bumper. two come in from behind the lens and are visible one from underneath. once you have those out you have to finagle the lens out of the area there isnt a lot of room to get it past the fender and bumper covers but it can be done.
Old Dec 25, 2012 | 04:46 PM
GHall8788's Avatar
Thumbs up
awesome looks great, thanks guys
Old Dec 25, 2012 | 05:00 PM
TImmy_Jones's Avatar
They do look good...post pics up. I had black projectors and black corners on my Z.
Old Jan 1, 2013 | 09:07 PM
GHall8788's Avatar
will do as soon as i am home, on the 5th
