Superbrightleds- Map/rearview & rear dome LEDs
Nice sjs.. In your opinion are the tails/sides worth upgrading?
I am sure they are 3157, I don't want to post that for fact u.til I can post the part number that I installed and fit. I don't want someone to blame me with the but you said these would work.
Too many led threads with, I think this should work instead of 100% accuracy with part numbers and year/make of car installed on.
I will edit op tonight with part numbers and pics.
#32
yes........LED upgrade is well worth if only to keep the hot bulbs from melting housings......plus they are brighter ![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
the rear LEDs in mine were all 3157 45 smd dual intensity.......red for brake turn and cool white for reverse
and the oversized 194 for the end in the tails.......you can see the P/N in the pic
http://www.superbrightleds.com/morei...edge-base/206/
194 ....5 smd...for the side markers.....2 in red and 2 in amber
also used the same ( 5 of them ) red for the speedo in the dash
and a 1 smd 194 ....cool white....for the license plate......anything else will not fit........ask me how i know
and dont forget the FULLY electronic flashers ( 2 of them ) ..........P/N in the pic
#33
for the side markers.....in red and amber
and a 1 smd 194 for the license plate......anything else will not fit........ask me how i know
4X3157 RED for the tails/stop (Can't rememb
2X194 RED *oversized for the corner of tails
2X3157 WHITE for the reverse
*I already have an LED 3rd brake light
4X194 2/RED 2/AMBER for the front/red side markers
2X3157 AMBER for front turn signals
2Xelectronic flashers (can I get the part number please)
I already have one of the aftermarket LED 3rd brake lights so I'm good there.
#35
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I got lost about the Electronic Flasher.
Where does that part go?
I had these same led bulbs in my front turn signals but they kept shorting the housings.
I guess this part your talking about fixes that but how/where is it installed?
#37
Let me know if this covers everything for the exterior:
