Some Plasti-Dip Action-
I never insisted on plasti-dipping my *****, I just did it because I had leftover paint, and figured why the heck not? Plus, it's temporary and reversible with no damage to the stock parts.
It's a pain to get good coverage, I need to touch mine up as I found out after it dried, I was a little light on a few passes in certain areas. Not noticeable unless you're looking for it though.
One thing I HATE about the black top... it shows dirt/dust like CRAZY! BAAHHH!!
My hood isn't perfect, but hey, it's a large flat area. I've gotten pretty good at the sail panels.
Oh, be sure not to leave the plasti dip where the ttop sits. I did it the first time and after sitting in the sun my top pulled it up. I'd do it with the tops in and just take a razor blade to the edge to be sure. Don't worry about overspray on glass, it doesn't stick. Over spray on paint is a pain to get off though
Exactly.
I thought about it... I may do it... just afraid it might be too much.
You do realize it's all the same stuff right? Meant for similar purposes. Read the can, and tell me where it says it's NOT meant for things you'll be touching.
Make sure you take pics!
I have 3 coats on the chrome grille of my Cummins and it has been holding up for over a year. Sure it has some rock chips but no peeling. I'm going to spray the bumper once it warms up and I'll redo the grille if I feel like it.
Has anyone tried Mother's Back to Black on plasti-dip? I got a little on it, and it made it more of a glossy finish. I've read some truck guys use it, but I'm curious if it eventually just ruins the plasti-dip.
I plasti-dipped my ***** on 2/18 and they showed no signs of peeling/wear/etc. Until last week 7/1 when I was working on my head unit wiring and the headunit was hanging down. Well, dummy me let it slip at one point and it scraped the HVAC *****, tearing the plasti-dip.
Left them as is until today, pulled them, easily peeled all the black off, and layed on a few coats of Krylon Fusion Gloss Black.
I really wish I hadn't jacked up the Plasti-Dip. I truly wanted to see how long they'd last. Whatever, 4.5 months with zero signs of wear kind of debunks any thought that with normal use on a daily driven car, PD will hold up.
Side note- the rear window defroster button still has the PD on it. I didn't feel like pulling the HVAC panel apart just to shoot it with a coat of paint. Maybe if I can find a small enough decal, I'll paint the whole thing black and then put the decal in the center like stock. Or just get one off a Camaro.
