In the middle of removing side molding, need help
Old Feb 12, 2013 | 01:43 PM
DrBlockHed's Avatar
Default In the middle of removing side molding, need help
I just pulled off the first piece of side molding on the passenger side. It pulled off pretty easily leaving minimal glue behind. I can't seem to get the last bit off. I've tried goo gone and that hasn't worked. Is this in fact glue that I need to just work more, or is it clear coat and I need to wetsand it? It is raised slightly when i run my finger across it
The paint under the molding seems to match the body fairly well.
Help appreciated
Attached Thumbnails In the middle of removing side molding, need help-imag0455.jpg
Old Feb 12, 2013 | 02:37 PM
Zerokube's Avatar
i had the same thing and ended having to do a light wet sand to get it off, it was actually embedded in the paint. Even now its still kind of there.
Old Feb 12, 2013 | 03:00 PM
DrBlockHed's Avatar
Pulled off the rest of the molding, its only that one spot.
What grit is recommended?
Old Feb 12, 2013 | 03:27 PM
bigken's Avatar
Myabe you can try to use a clay bar and or a cleaner wax to get it off? Mine came off easily and I was able to get off all the tape just using my thumb to roll across it.
Old Feb 12, 2013 | 03:38 PM
DrBlockHed's Avatar
The rest came off with a damp rag... I think its clear coat, nothing is taking it off. Can I wet sand it?
Old Feb 12, 2013 | 03:40 PM
ramairetransam's Avatar
id try some a hair dryer and your finger nail. then a claybar . if that doesnt do it , then some scratch x on a mf towel and buff it clean .
Old Feb 12, 2013 | 03:59 PM
DrBlockHed's Avatar
Ive been using a heat gun, finger nail and then wd-40. All did nothing. When I use a clay bar, I need lubricant correct?
Also is the scratch x a polisher/buffer? Or a scratch remover, how aggressive is it, how careful should I be?
Thanks
Old Feb 12, 2013 | 04:10 PM
Daniel Richards's Avatar
odds are it's clearcoat, I ran into a similiar situation on mine http://www.fullthrottlev6.com/forums...elete-Write-up one side was perfect after using Goof-Off but the other side had what looks like yours, I never bothered to fix it as the clay bar did NOTHING, you will most likely need to wetsand and buff it to get rid of it.
Old Feb 12, 2013 | 04:19 PM
DrBlockHed's Avatar
I figured there isn't much else I could do as far as goof off, clay bar etc, I'm pretty sure I'm limited to wet sanding. What grit would sand down the clear coat lip w/o eating into the paint? I tried 1500 for a minute but am hesitant due to not wanting to screw up my paint job. If it's going to be a PITA, I'll leave it as is, it's hard to see if I don't point it out.
Thanks
Old Feb 12, 2013 | 05:31 PM
definitely nothing heavier then 1500, would probably go more like 2000 or 3000, just go lightly and plenty of water. all you wanna do is knock down the "ridge" so I would use a block to hold the sand paper. then you'll need to buff it out good.
Clay bar and spray detailed for lube and scratch x just do it by hand
Old Feb 12, 2013 | 06:10 PM
DrBlockHed's Avatar
Can i buff it by hand or do I need a PC? Im going to wash the whole car and wax it sometime within the next week or so, anything specific recommended for waxing/buffing?
ramairetransam, do you think the scratch x has a shot to fix the lip?
