Fixing a HEAVILY oxidized test panel!
Here's a write up from our friends at Adam's Australia:
Hello Ladies and Gentleman,
Some of you may have seen a recent post of mine regarding a hood/bonnet found at a local Wrecker.
The back story can be found here: Adam's Polishes Results - Adam's Polishes Forums
Mook asked if I had taken pictures of the process and I did, so here they are.
Image 1- Bonnet as found with visible rust defects.
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/1_zpsa5ef143b.jpg)
Image 2- Taped off and ready for a barrage of Adam's goodness
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/2_zpsa46c6cec.jpg)
Image 3- Car Wash Shampoo and APC wash
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/3_zps7ecf55d4.jpg)
Image 4- Post wash result and ready for Detail Spray and Clay Combo
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/4_zpsa6532e10.jpg)
Image 5- New Clay kneaded
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/5_zps42ee5b56.jpg)
Image 6- Sister assisting in Claying. Oxidation and grit on Clay
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/6_zps964a85ff.jpg)
Image 7- Clay close up
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/6a_zps8e2e9c0c.jpg)
Image 8- Post Clay and ready for Adam's 3 step Machine Polishing System with Gen4 Pads using PC 7424XP
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/7_zpsd582e736.jpg)
Image 9- Adam's Severe Swirl Remover 4 passes at 5000 opm
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/8_zpsa9b8b2d6.jpg)
Image 10- Post Severe Swirl Remover passes
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/8a_zpsfea56efc.jpg)
Image 11- Adam's Swirl & Haze Remover 4 passes at 5000 opm 1 pass at 6000 opm
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/9_zpsd250d2fd.jpg)
Image 12- Post Swirl & Haze Remover passes
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/9b_zps4446fbd7.jpg)
Image 13- Adam's 4" FOCUS Pads at work for stubborn scratches. Using Metabo Cordless Drill with 4" Drill Backing Plate
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/10_zpsb7774598.jpg)
Image 14- Swirl and Haze with pea sized drops
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/11_zps4599dd26.jpg)
Adam's Machine Super Sealant and Brilliant Glaze were applied at the end. (forgot to take photos)
Image 15-20- Assorted Shots of finished result!
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/13_zps1110f3d5.jpg)
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/14_zps219a7e42.jpg)
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/15_zps5f95bbaa.jpg)
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/17_zps8fd7fe24.jpg)
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/18_zps0cb5e36e.jpg)
![](http://i1308.photobucket.com/albums/s610/adamspolishesaustralia/19_zps22aa445e.jpg)
Thanks for looking!
Thanks for looking!
The comparison looks great, but not really fair because that is clearly single stage paint. If you polish a newer car and see color on the pad, you messed up big time. Of course you can bring back a single stage paint that looks that bad as long as there is enough paint. If it were base coat/clear coat (BC/CC) paint that looked like that dull, it's highly doubtful it could be salvaged. More than likely has clear coat failure or on the verge of it.
