Map Light LEDS please help
Old Feb 25, 2013 | 08:47 PM
TxOutlawZ28's Avatar
Default Map Light LEDS please help
I need help guys, I replaced the dome light with a blue bulb from superbrightleds.com and I cant seem to find which one I need to replace the map lights (rear view mirror)
it has been suggested the wedge light but I thought thoose were for the dash/gauges
Old Feb 26, 2013 | 01:27 PM
73CamaroLT's Avatar
What year? I bought a festoon bulb for my 2002 but found out it was wrong. I think the 01-02 camaros need a wedge bulb.
Old Feb 26, 2013 | 02:45 PM
Ls1CamaroGuy87's Avatar
If you do both MAP and trunk light, one set will stay on all the time unless you solder in a extra resistor. At least that's how my Camaro was,,,
Old Feb 26, 2013 | 03:52 PM
cemlsx's Avatar
Dont know camaros but I used this in my Firebird..
As for the trunk light, I swapped out the stock light bulb with an LED strip, no problems with anything staying on..
Old Mar 27, 2013 | 08:43 PM
BadBirdie's Avatar
hey can you (or anyone) explain how to wire in a resistor for the map lights? im having the problem where the leds are staying dimly lit all the time. i know it wont drain the battery or anything but it will annoy me.
Thanks
