Where to buy simple green?
Old Apr 10, 2013 | 07:49 PM
mhugney's Avatar
Default Where to buy simple green?
So I'm looking to buy some simple green to clean my engine bay with, and it seems all I can find are the huge 5 gallon sizes! I've checked amazon and the regular sized containers are few and far between, and each one has an estimated $20-$30 shipping charge! Ridiculous! Anyone know the best place to buy it? Also, if you know of anything else I should buy that will help out with the cleaning of my engine bay, let me know! Thanks
Old Apr 10, 2013 | 07:56 PM
redbird555's Avatar
Autozone and advance sell it in bottles just make sure you don't let it sit on the aluminum too long or dilute it heavily
Old Apr 10, 2013 | 07:58 PM
Earnhardt's Avatar
Be careful with aluminum engine blocks...
Aluminum - Is it safe to use Simple Green® on aluminum?
When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green® Cleaner/Degreaser, Simple Green Pressure Washer Concentrates, and Pro Series™ Simple Green® Automotive Cleaner have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green® product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
http://www.simplegreen.com/solutions...ckup=aluminium
Old Apr 11, 2013 | 06:24 AM
SS LeadFoot's Avatar
Home Depot
Old Apr 11, 2013 | 06:48 AM
senicalj4579's Avatar
walmart
Old Apr 11, 2013 | 03:59 PM
Mr. Trick's Avatar
Ace hardware.
Old Apr 11, 2013 | 06:21 PM
I8UR4RD's Avatar
everywhere lol
Old Apr 11, 2013 | 07:30 PM
HotWhipT/A's Avatar
Originally Posted by I8UR4RD
everywhere lol
Bingo!
Old Apr 12, 2013 | 02:04 AM
Fosnot's Avatar
Advance has it in the big 5 gallon jugs in the back at the Commercial counter
Old Apr 12, 2013 | 08:24 AM
2GOOD4U's Avatar
You can find it just about anywhere out here. Since you are using it on your engine bay, make sure you dilute it. Even diluted, it still works very well.
