First time paint correction questions
I think I'm ok on the flat panels (hood etc, although what about the center where the two bump outs go back in?) but when coming to an corner where the hood transitions to the fender, is there a trick to doing this? I know the PC is safer, but it vibrates too much for my liking and I like that the Flex works much faster.
I've been reading a lot about burning into edges, is this more sharp edges or the hood/fender transition edge? I don't want my paint to look worse after I correct it.
Last, the rear black panel w/ the TA logo, what's best to use when polishing that? I have mostly Adam's products, fyi
Thanks
Notice the pad @ 6:00.....
Look again @ 7:20 RED PAINT ON THE PAD
And this guy charges $700-900 for "Light" paint correction
Point: you absolutely can burn paint with the Flex.
Also, how do I manuever around the corners of the car? Do I just maintain the pad as flat as possible? I'm not going to do any sharp edges at all (i'd rather it look a little crappy then see metal!)
And for what it's worth, GoFast, I've read a good portion of your detailer thread.... Great stuff, appreciate you taking the time for us new guys.
Thanks
Thanks
Its the machine and the method more than the products. Skip the Flex, its not worth the cost, for that money you might as well get the Rupes 21 (best one available). But entry level polishers like the PCXP, Griot's 6" DA, and HD 6" DA are all good machines.
Tape off edges and take your time with it. These will not generate much heat anyway. Keep the pad flat, and keep it moving. Just articulate the machine around the curves.
Thanks for the kind words.
So it sounds like I should be ok as long as I'm careful and keep it moving. Any other important tips? I'm eager for my first paint correction but am actually a bit nervous....
And post finished pics!!!
