Trans Am seat question
Old May 10, 2013 | 10:36 PM
1bdbrd's Avatar
Default Trans Am seat question
My interior is in mostly good shape except for the bottom of my drivers seat. The leather is torn and the padding feels pretty gone. I would like to fix both of these issues because I can't find a set of seats that I feel look right inside the car that don't cost a small fortune. So can I buy a new foam bottom and a new bottom cover?
Old May 11, 2013 | 04:30 AM
Daniel Richards's Avatar
I believe your choices are to either search craiglist/junk yards for a used one in decent shape, or go to a good upholstery shop and have them redo the foam and make a new bottom, but you;ll be well on your way to new seat prices by then I would imagine.
Old May 11, 2013 | 09:40 AM
buellxb12s's Avatar
you would be amazed what steam does to foam. I worked at An upholstery shop and we would do that to double the size of foam before recovering em.
Old May 11, 2013 | 09:45 AM
1bdbrd's Avatar
Without taking it apart to be sure I think where mine is torn in the leather, it is also missing a good chunk of foam. It just feels like that so that's why I just wanted to get a new cushion instead.
I saw a thread on here a few weeks ago where the guy had a new lower foam but I can't remember where he got it.
Old May 11, 2013 | 04:37 PM
carlos64030's Avatar
Is it possible to make foam expand AFTER leather covers are installed? The seats from my Trans Am GTA just recently got new leather but they don't look as tight as they COULD be. Any advice?
Old May 11, 2013 | 06:51 PM
buellxb12s's Avatar
I wouldn't say its impossible but I was advised to keep the steam away from the covers to avoid the risk of burning the covering material. personally I wouldn't risk hurting those nice covers. I would pull the foam back out to do it if I redid it at all.
Old May 11, 2013 | 07:39 PM
Thank you, sir.
Old May 11, 2013 | 08:42 PM
LilJayV10's Avatar
Carlos,
Are you referring to the wrinkles in the leather? If so a lot of them will go away after the leather relaxes.
Very nice seats BTW.
Old May 11, 2013 | 09:15 PM
trik396's Avatar
I am going to be selling my trans am seats. They are tan and in decent shape.
Old May 11, 2013 | 10:59 PM
sjsingle1's Avatar
i have searched and HIGH and LOW.......front seat foam is not available for 4th gens
Old May 11, 2013 | 11:00 PM
Carlos,
Thank you. Yeah, I know the wrinkles will go away in time, but the leather still seems like it could be a little more tighter. The seat's foam is 22 years old, though... guess I really can't expect too much.
Old May 11, 2013 | 11:31 PM
LilJayV10's Avatar
You will have to get foam and shape it. There's a good write up on here how to do it. I haven't done it but it doesn't look that hard at all.
Old May 12, 2013 | 07:29 PM
1bdbrd's Avatar
Well FML. Looks like I am stuck with uncomfortable seats or buying overpriced "racing" seats that don't fit right or need overpriced brackets to fit.
Old May 12, 2013 | 07:51 PM
LilJayV10's Avatar
Search. It was on the first page.
https://ls1tech.com/forums/appearanc...ry-my-car.html
Old May 12, 2013 | 10:02 PM
1bdbrd's Avatar
I completely overlooked your post, oops.
Old May 13, 2013 | 12:20 AM
LilJayV10's Avatar
No problem. I didn't remember who started the thread. I searched for how to, and foam and got lucky.
Hopefully it will help you out.
Old May 13, 2013 | 11:11 AM
VIP1's Avatar
Copy & Paste Moderator
Most of the time, you don't need to replace the foam.
The foam sits on thin wires that cut into it. Disassemble the seat bottom. Put something thin/flexible/sturdy between the wires and foam. Reassemble.
In my case, I used some old screen material and aluminum tape that I had lying around to wrap the wires into a flexible metal shelf for the foam to sit on instead of just bare wires.
Old May 13, 2013 | 12:09 PM
astro11271984's Avatar
What I did was go to the junk yard and pulled the foam from a passenger seat, since those are the mostly the ones in good shape and used it on the driver side.
Old May 13, 2013 | 05:52 PM
1bdbrd's Avatar
That's actually a really good idea. I will have to look for one on ebay though since the junkyards here are full of the **** that not even the ghetto wants..
It's too bad that the camaro seats don't have the same cushions as I have a full set of grey leather camaro seats out of an SS that I could pull apart. That and a pair of Corbeau seats as well. I guess I could sell both to fund a new set of seats..
