How often?
Old May 26, 2013 | 12:36 PM
blackbirdls1's Avatar
Default How often?
How often should you wax a car? Mine is no longer garaged and I feel like I end up waxing it more than I should but I do live in sunny Florida.
Old May 26, 2013 | 01:10 PM
KingPin1094's Avatar
I usually wash my car once a week, and wax it every other week. Just how ive done it.
Old May 26, 2013 | 02:01 PM
LilJayV10's Avatar
Depending on if you are using a wax or sealant and where you live anywhere from 3-5 months.
You can over wax your car, after multiple layers build up it will start to make the paint look dull. If you strip the wax off everytime then re wax it thats a different story but that just seems like a lot of work.
Old May 26, 2013 | 02:03 PM
LilJayV10's Avatar
Also claying will help your wax/sealant last longer too. For maintenance claying use a fine or ultra fine grade. Some medium grades will leave marring which will require a light polish.
Old May 26, 2013 | 05:20 PM
Well when you wash it it takes some of the wax off right? Thats why i always rewaxed after every two washes.
Old May 26, 2013 | 05:39 PM
Blownbayou's Avatar
Wash (or wet and wipe) once a week and wax usually 3-4 times a year. Car does not see rain if I can help it.
Old May 26, 2013 | 07:50 PM
LilJayV10's Avatar
Unless you are washing it with Dawn no.
Old May 26, 2013 | 08:45 PM
LilJayV10's Avatar
I see your point but I would think it would be minuscule if any would be removed when you are washing. My guess is wax/sealant manufactures take washing into consideration when they give recommendations for how long their product lasts.
Old May 26, 2013 | 09:08 PM
9WhiteCamaro9's Avatar
I would do mine every other month to every 3 months but that's just me though.
Old May 26, 2013 | 10:31 PM
Blackpanther99's Avatar
Every 2-3 months will be good. Washing it every weekend will help meanwhile.
Old May 27, 2013 | 07:16 AM
Transmarrowbird94's Avatar
Sounds stupid but wash it with dish soap to take off old oils and wax then switch to car soap then wax comes out amazing
Also in between wax jobs use that quick detail stuff it makes it look like it was just waxed and u can do the car in under 5min
Old May 27, 2013 | 12:23 PM
LilJayV10's Avatar
There's no need to do that everytime.
Old May 28, 2013 | 01:24 PM
Adam's Polishes's Avatar
The only real true sign of how your wax is holding up is to watch your water beads when you are washing the car.
If the beads are still nice and small, then your wax is still doing it's job. Once the beads start to grow larger and the water begins to cling to the paint, then it's time for another coat.
As mentioned above, too much wax will have negative effects on the appearance of your paint. Only do it when needed.
Old May 28, 2013 | 01:38 PM
Reject's Avatar
couple of years ago i Ziano'd the Corvette and the wax lasted a LONG time. Alittle over a year and was an outside car. I'd wash it almost every Sunday and it kept on shining no problem. The truck on the other hand.... it gets washed when it rains outside LOL
Old May 28, 2013 | 04:05 PM
What's the most efficient way to apply zaino? I don't own an orbital buffer. clay bar, wash, zaino a good method?
Old May 28, 2013 | 04:31 PM
Reject's Avatar
i did all of it by hand. it's not hard and is simple to do. maybe on a sunday or something doing the whole wash claybar wash wax thing and be good for a long time. like i said all i ever had to do was just wash it and the shine stayed strong.
i did it by hand btw because i didnt want to buy a buffer if i wasnt going to be using it all the time anymore
Old May 28, 2013 | 04:35 PM
Reject's Avatar
just a basic picture from the phone
i remember that picture because it was the first wash after coming back from deployment
Old May 28, 2013 | 04:39 PM
Yeah i think im going to pick up the zaino kit and give it a shot, it seems very concentrated and easy to wipe off? I don't own a garage so anything I'm looking to do has to be done in an efficient manner.
Old May 28, 2013 | 05:05 PM
JustAFooL's Avatar
Like Nick said, your car will let you know when its time to wax. Mine stays in garage so usually a full clay once a year and wax maybe twice??
Old May 28, 2013 | 05:21 PM
Reject's Avatar
while i was in Ca the car only went in a garage on weekends. during the weekday it stayed outside in a dirt "parking lot" with the marine layer coming in every night at around 3am and people driving up and down the parking lot the car would be dirty with dust again inside of an hour.
