Retro Style Trans AM Tail lights DONE
#63
As far as the lighting on the outside, I really doubt there would be a heat issue. The tails are huge Not sure if I will get to it this weekend but I will see what I can do.
#69
#71
Thanks!
I will eventually redo them with paint as it is just plasti dip for now because I wasn't sure if I was going to like them or not. But they did turn out great so I'm sure it'll hold up for quite awhile. Stripes and Ceta are done in it also. Should be fine until I repaint it.
Hopefully I will have it good to go by Wed then I can get some good outside pics
#76
I think they are a great change. I was thinking about doing some just like that but keeping my honeycombs too for when I need a change. Both are a good look on these cars. Are those led's in the reverse lights? Do they actually make a noticeable difference from the drivers seat or are they just bright when you look at them?
#77
They are all just stock bulbs and the reverse lights are LEDs. They are from v-leds.com. They must have taken them off their site now because I don't see them. I'll take a picture and post it.
Thanks! NO YOU CAN'T
#79
Yeah mine had that problem when I attempted to do a sequential mod with LT1 camaro tails. Dimpled my tail light lenses on the corners so then I bought some Euros with black background and switched to LEDs. LEDs do not run near as hot as these incandescent bulbs so it worked great!
#80
Yea my fronts are switchbacks from Vleds and I bought the reverse ones at the same time. All the interior lights are leds also. The only lights that aren't are the rear marker lights (need to get some red ones) and all the tail lights.
