Finally installed 6LE/Mcnord gauges, bezel, and LED's...
On a side note, I read on another post that you can replace the soldered bulbs built into the cluster and it should help alleviate the dim light issue... has anyone done this with success? If so, what bulbs do you use?
As always, thanks for any help.
