HID's in fog lamps
HID's in fog lamps
I had HID's installed in my 02 Trans Am fog lamps, I have read and some people have had luck and some they melted the lens.
I don't use the fogs much and the plastic lens is starting to melt, the bulbs almost touch the lens,...did they use the wrong bulb? I don't know much about HID's but there are different size bulbs...is there a size that works and will not continue to melt the factory plastic lens and will work with the ballasts that are on my car?
And I messed with trying to get one of the housings out to see if I could read the bulb, man it's tight, I removed the two screws and tried to push the bumper out to slide it out but it didn't want to come out...is this the way to remove them?
The stock housing isn't made to handle HIDs, so no bulb is right unless it's the halogen replacer. I suppose it could work with low profile hid bulbs, but they would still reflect terribly and blind oncoming traffic since it is not a hid projector.
I would either get new stock housings and go back to halogens (looks crappy I know) or get some better fogs that handle the hid setup.
I have HIDs in my fogs, but i use low profile bulbs, and glass/metal housings. I aim them very low to avoid any poor reflections.
first, typically most of the HID "bulbs" out there are the same "tube" simply installed on whatever base is the type of light your installing, which in this case should be an 880, if you want to avoid this problem your first option is to switch back to stock halogens, next is to track down someone parting out an LT1 4th gen (they have glass lenses and metal housings so they won't melt) or a cheaper option is to switch to a different light entirely like in this thread http://www.fullthrottlev6.com/forums...in-98-Firebird (it's on here to I just didn't wanna search for it) this is what I'm fixing to do, HID in non projectors just puts out to much glare.
Where did you get your LED's at, I got some and they where even dimmer then factory halogens and they had a real bad tendency to flicker (not flash like there supposed to) when I unarmed the alarm?
I got the LED bulbs on Ebay and they have never flickered on me. They have 68 LEDs on each one so they are pretty bright, but they don't cast as much light as HID bulbs. I wanted them to match my HID headlights and not melt the lens so I'm ok with that. I wasn't looking for light output since the HID headlights light up the road very well.
This is the style that I got, you will have to search for a bulb size that fits your socket:
http://www.ebay.com/itm/H16-White-LED-Bulbs-68-SMD-Super-Bright-DRL-Fog-Light-lamp-/280763994528?pt=Motors_Car_Truck_Parts_Accessories&hash=item415ed691a0&vxp=mtr
I have HID's in my fog housing on my TA. Let me see if I can dig up some pictures. Since they are low they aren't blinding but are bright as hell so I rarely use my headlights. I'll get a night pic too to kinda show the "cutoff". The light goes right to the top of the license plate of cars in front of me and no higher but out quite a bit. I've had no problems with deformation or melting.
