dash pad repair *back support question*
am going to leather wrap it. i dont feel confidence enough preparing it and painting it. the cracks are slightly uneven do i need filler or just slap the leather on and call it a day? sorry for the long post. opinions are appreciated
thanks! Also what do you mean cracks are uneven?
uneven is that 1 of the cracks is slightly raised in proximity to the other, thats the closes i could get them to fit. am thinking to use filler but am getting real busy..
you could use fiber glass sheets to reinforce it. i was going to but i couldnt find any, i dont have good working space (am doing this in my bedroom lol) and no availability of such materials here in middle east..ugh
Instagram: _skid87
First I trimmed the piece to an approximate size, then sprayed the adhesive on both surfaces like the can said and then slapped it on there. At first youll think wtf did I do wrong because itll be all wrinkly and appear like itll never lay down smooth. I then used a hair dryer and a bondo spreader and just worked it for what seemed like an eternity. Then I trimmed the edges to an inch or so and hot glued them to the back side, this only works marginally well. Id use some more of that adhesion spray if you had it, I ran out.
If I had it to do over again id do the vent different, thats the only place I half assed it and it shows. I just cut an oval all shitty with a box knife, I should have cut strips and pulled them through the vent and glued them to the back side I think.
When I tried to wrap mine in vinyl it came out bad (I'm not very crafty) and as stated it will reflect in sunlight. Kind of annoying seeing your dashpad on the windshield as you are driving.
The carpet is keeping it all together on the topside and looks OK, the underside is doing alright. I'm going to pull it again though, I reinforced the one section too much so the edge is up in the air a bit, going to take care of it so it sits flat and plan to add piping of some sort to it so it will look more finished.
looks like you only live about an hour away form me.
and i dont like the AC vent that much..i could have done a better job but i lack the correct tools..ugh all in all i can live with that! id get it to look perfect if i could do it again but oh well..
