Good Quality headlights for 2000 Camaro?
So yeah looking to get rid of these headlights quickly with some good quality ones with halo's and HID, I wouldn't mind just headlights with 10k hid's in them at this point. Suggestions?
Does anyone know if I could just buy some stock headlights and change the light output? Like a 8000k light output.
I like the blue-ish lighting. My concern is, can you change change to a different bulb? Or what has to be done? Saw some pics of stock headlights with what I want. Idk whether you can put HID bulbs in or not.
-also, are all these aftermarket projector headlights/halo headlights junk? Any of them decent quality?
Another that is OK for HID are the Sonars from ebay. They're OK. I thought they were better than stock halogen lights (and don't even start with HID in stock housings! yuck). BLS are definitely better though by a good bit.
Besides those, nothing else really works too great with HID. There are a few different "ebay" lights but from experience with two of them and seeing pictures of a 3rd the rest aren't too good.
Reason why I ask is because the r8 style headlights that I did purchase and finally installed (which was a huge pain to even fit into the car, had to jam it), they stopped working. After driving it back on my way home, I turned my high beams on (which weren't bright at all), then when I saw a on coming car I switched back. But, I noticed there wasn't light. Pulled over and my low beams stopped working.. Now only led's and high beams work.. Luckily I was in the city to make it back home safely. Now the ballast box makes a buzzing noise. Worst quality ever and hasn't been installed for more than 8 hours and with less than a hour of being turned on.. Cut-off was bad too, let alone the weather strip was falling off from the begining of the installation. Send a HUGE complaint to the company and without even responding to my comments just gave me info on getting my money back when I ship the headlights back. Even though I'm being charged a 20% fee.. Better than not having any money back and stuck with these pieces of junk.. I'd advise everyone to stay away from these.. Such a pain and not worth it at all.
So, that's why I was wondering whether these other "projector" headlight companies have the same terrible quality, or some better than others?
If worst comes to worse I'll have just stock headlights and be done lol. I'm considering a pair from BLS.
If I can find the picture of the headlights I want I'll post them. Had no halo's, look like a fairly stock headlight assembly but the light output was like blue, thought they were really cool. Perhaps those were BLS lights, I'll take a look again.
Thanks,
Blake
I did check their site, I did see a pair that was near that price, but didn't match your description. Is Anzo good quality? Quite curious.
Thanks,
Blake
For stuff like headlights I don't want to skimp, I want something I know will work. That's why I shelled out for the Morimoto HID kit. Which at $150 ish still isn't that bad.
http://i60.tinypic.com/24l05xs.jpg
Stock headlights with an HID kit. Nothing special.
If the headlights in the pic are in fact stock, is it safe to put hid in stock considering those are reflecter housings? Heard it wasn't a good idea.
It is odd both went out at the same time, unless you're using a relay harness. If you are, it is possible the relay is bad.
"Safe" to put HID in stock housings is a relative term. Some people will swear up and down it is perfectly fine. Technically, it isn't
Our stock headlights certainly aren't the worst offenders when it comes to glaring with HIDs, but that doesn't mean they're good either. Just do it right with projectors
For how much some of these aftermarket lights cost (like those Anzos for $350 that DemonicZ mentioned) I'd just get the basic BLS kit! Same cost, far better lights. Then put in a HID kit of your choice (again I'd do the Morimoto 35W kit from BLS or theretrofitsource) and you're done. That gives you a Whistlered light with projectors in the low beam bucket (bixenon so they do highs also when the solenoid is wired up). Nothing too fancy but works well and looks nice.
Yeah, aint that the truth.
