Aircraft Remover??
Old Apr 26, 2014 | 09:40 PM
DirtyBirdMKE's Avatar
Default Aircraft Remover??
read a bunch of threads about using aircraft remover to remove tint... just wondering if anyone has done it and if it harms the defroster on the rear window.???
i found it at autozone by rustoleum
Old Apr 26, 2014 | 10:03 PM
Daniel Richards's Avatar
seams a bit extreme to me, I'd be afraid of it getting on the interior, or for that matter the paint, myself.
Old Apr 27, 2014 | 04:14 PM
contraststriker's Avatar
dangerous to use paint stripper on the window, I wouldn't recommend it--I used soap/water, 0000 steel wool, and a sh*t load of patience. I also made sure the car sat in the sun for a good hour before starting.
Old Apr 27, 2014 | 05:53 PM
here are the 2 most generally accepted methods for doing the rear window:
Old Apr 27, 2014 | 06:51 PM
jig's Avatar
jig
just steam it off...easiest tint removal you will ever do..
Old Apr 28, 2014 | 09:35 AM
RebelExtrm02's Avatar
Simple Green. I'm serious. Soak the tint with Simple Green. Press black plastic trash bags cut to the shape of the window against the soaked tint. Sit the car in the sun for a half hour to an hour. Slowly peel the tint off while spraying more simple green where you're peeling to keep it wet. It works as good, if not better, than the amonia method without burning your lungs, making the car smell horrible, or hurting your interior. I've done this on three cars now with over 10 year old tint on them. Left no glue/residue behind and didn't damage the defrost lines on any of them either.
For the back window in my TA i had to use vertical strips of black trash bag because I couldn't get one large piece to stick long long enough to get it across the whole window.
Old Apr 28, 2014 | 09:46 AM
2nd Gen Fl 'bird's Avatar
I would say no as well. Defroster would most likely delaminate from glass.
Old Apr 29, 2014 | 10:51 PM
LilJayV10's Avatar
I would loose my freakin mind if I knew the guy who tinted my windows sprayed 409 all over inside of me car. You can hear the girl running the camera asking him about when he's doing it.
Fail.
