New Headlight Style Opinions
Copy & Paste Moderator
This headlight retrofit on a Miata may interest you:
http://www.hidplanet.com/forums/show...h-quad-Mini-H1
He used the Morimoto Mini-H1 6.0. I'd recommend the new D2S 3.0 version instead if you can fit it (it is slightly larger than the Mini H1 6.0). Also, this setup is not completely sealed, but that can be mended a bit.
On second thought, the Morimoto D2S 3.0 may be too tall. It uses a 3.0" lens. The Moriomoto Mini H1 6.0 uses a 2.5" lens.
However, there is a version of the Mini D2S that has a 2.5" Square lens instead of round.
If you want smaller, you can try Corvette C6 projectors. TRS has them in the Closeout section for $25. That's too cheap. Hopefully nothing wrong with them.
None of these are sealed projectors. You'll have to build a housing to contain them. The link above has one way to do it, but it still isn't completely sealed.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I think the sleepy eye look could be pulled off with the right HIDs, custom shroud, and having the outside covers be as horizontal to the ground as possible when opened. The only time anyone on the road is going to be able to see it anyway is going to be in inclement weather, and I doubt they'll be too focused on your car in that situation (hopefully). This is all assuming they would still be able to open and close, and only be open when the lights are on.
I personally don't like fixed headlights on the birds. I think they look terrible in the daylight. It messes with the overall look of the car, in a bad way. Again, this is all opinion.
OK, I see one thing alot of you guys seem to be unaware of, getting the headlights to stop raising halfway up is actually relatively easy (and they would still close like normal).
this is because of how are headlights raise, are headlights have this little "swing arm" that rotates (down by the headlight motor) and when that arm hits the "stop" the current load increases and that tell the motor to stop, due to this all you have to do is create a new "stop" for the arm to hit positioned to allow the headlight to raise to your desired height and you will still have functioning pop-ups just now they are sleepy eyes.
