2011 Camaro Wet sand and buff
Old Oct 29, 2014 | 09:33 PM
FASTFATBOY's Avatar
Default 2011 Camaro Wet sand and buff
I do not recommend wet sanding. This car was wrecked, repaired and the entire car was re cleared with 3 coats.
Work was done with a Porter Cable 7424 XP, Lake country orange pads, Meguiars M105-M205.
Start
M105
Hood completed M205 no wax
Completed , M205 no wax
M105
Completed M205 no wax
Old Oct 29, 2014 | 10:45 PM
jaxcam02's Avatar
Impressive work
Old Oct 29, 2014 | 11:08 PM
LT4vert's Avatar
I admire your patience doing that with the porter cable. Great job man!
Old Oct 30, 2014 | 03:20 AM
The Guz's Avatar
Nice job. Next time you wet sand look into Meguiar's microfiber cutting pads. You will like how they cut compared to foam.
Old Oct 30, 2014 | 08:34 AM
Spd-Kilz's Avatar
Impressive. Well done.
Old Oct 30, 2014 | 06:12 PM
Jimbow's Avatar
Great work man, I don't have the patience to do that with a porter cable lol
Your results look great
Old Nov 2, 2014 | 05:58 AM
FASTFATBOY's Avatar
Link?
My LC pads pack up really quick, one per panel using M105. This gets old.
Thanks guys, car looks really good.
Old Nov 2, 2014 | 09:58 PM
The Guz's Avatar
These are the Meguiar's microfiber pads. You can use them with any of their compounds. But compounds such as M105 and M101 will dust. The pads were designed to be used with D300. You should upgrade to M101. Much better than M105. Works really well with foam. I think their M100 works really good with microfiber. If anything I believe Michael Stoops over at Meguiar's would recommend going M100 if D300 doesn't cut it (pun intended).
Microfiber pads
http://www.autogeek.net/5in-microfib...ing-discs.html
D300 compound
http://www.autogeek.net/meguiars-da-compound.html
