View Poll Results: Which lights look better on an NBM camaro? (remember I am doing whistler mod too)
Clear corners
80.00%
Black baground corners
20.00%
Voters: 10. You may not vote on this poll
Clear corner lights or black ones?
Old Feb 6, 2015 | 09:55 AM
Tonyz400's Avatar
Default Clear corner lights or black ones?
Quick question guys:
I have an NBM ss camaro I am doing the whistler mod on this weekend. Since I have the headlights out I figured I would take the chance to change my corner lights as well. my question is should I go with clear corners or should I get the ones that have a clear lens with black background? If I had a lighter colored car I would go with the black backing but since my car is so dark I don't all the details to sink into the vehicle like a blob. Anyone with navy blue camaro pics would be a help. I also have polished ZR1's as well so people with polished wheels could be even better but not needed.
Old Feb 6, 2015 | 11:40 AM
jaxcam02's Avatar
Stay with you stock ones unless you like blowing bulbs all the time and melting those cheap *** aftermarket ones. Ive bought three pairs of them and every single one of them have blown bulbs and melted the housings. And thats without even mentioning the fact that the aftermarket housings wont allow for reuse of the socket gaskets in charge of keeping water out.
They are a great idea if you are going full LED's in the corners but if you are sticking with halogen bulbs, DONT DO IT.
Old Feb 6, 2015 | 11:47 AM
themealonwheels's Avatar
Yep. The black housings I had kept blowing bulbs. I finally switched back to stock. When I had the black housings out, I happened to notice the inside was literally melting! Screw that...
But if you really want a darker corner lens, go with the "smoked" ones. They're the same black housing, but the part around the bulb is chrome. Kind of like the whistlered headlights. I've had these in for a while, no melted housings.
Personally, I think you should go chrome.
Old Feb 6, 2015 | 12:19 PM
Tonyz400's Avatar
Do yow know where I can find some of the chrome ones your mentioning?
Old Feb 6, 2015 | 02:43 PM
stealth355tpi's Avatar
Depo brand black ones here with the reflector in the back of them. Haven't blown any bulbs.
Old Feb 6, 2015 | 02:55 PM
scotty2000ss's Avatar
I bought corner lens covers from Hawks third Gen. I like how I can take them off at any time.
Old Feb 6, 2015 | 03:04 PM
Tonyz400's Avatar
Is it possible to get that GTO label off with paint thinner or anything like that? That label just doesn't jive with my vision of "Clean" for the car
Old Feb 6, 2015 | 03:08 PM
Yup. It's just a sticker. I took it off after the picture was taken.
Old Feb 6, 2015 | 03:42 PM
jaxcam02's Avatar
Curious as to how those lens Covers go on. Do you have to take the corner lights out or do they just slide in the space between the corner lens and the bumper?
Old Feb 6, 2015 | 03:49 PM
They slide in one end and have special velcro on the other end.
Old Feb 6, 2015 | 09:19 PM
chrysler kid's Avatar
Stock.
As mentioned the aftermarket versions melt and fill with moisture.
Blacked out is just too much overkill, I'd like to see a full led version come out through then I'll spring up some dough
Old Feb 6, 2015 | 09:52 PM
Tonyz400's Avatar
maybe I will buy the shades or stay stock. I know the navy blue cars are tricky because sometimes it almost looks black which means anything black just sinks in and makes a blob : /
Old Feb 6, 2015 | 10:06 PM
The Guz's Avatar
You want these if you want to avoid leaks.
http://www.ebay.com/itm/400857592892?_trksid=p2060778.m1438.l2661&ssPageName=STRK%3AMEBIDX%3AIT
Old Feb 6, 2015 | 10:10 PM
jaxcam02's Avatar
^^^ that looks exactly like the three pairs ive bough that have the trifecta of leaking, melting and blowing halogens
Old Feb 7, 2015 | 09:17 AM
1993 2002 Chevy Camaro Black Front Bumper Signal Lights | eBay
These are the same ones I run
Old Feb 7, 2015 | 10:09 AM
Tonyz400's Avatar
Now I know this may be a dumb question but do you drive your car in the rain? Do you have the lower splash guard still on your car, or is the moisture simply from washing your car?
Old Feb 7, 2015 | 01:34 PM
SparkyJJO's Avatar
I had problems with melting, leakage, and blown bulbs on the black ones in the OP, but the Depo ones that Guz linked to I had no issues with on my old car.
Now I'm just running stock corners that I tinted. They aren't totally blacked out but they aren't that glaring orange either.
Old Feb 7, 2015 | 06:53 PM
jaxcam02's Avatar
It's an out side car. The problem I was having is that none of the previous housings I've had would fit snugly with the stock socket gasket/weatherstripping. The socket would either fit only without a gasket or much to snuggly that the gasket would deform. A slight rain and moisture gets in.
Old Feb 9, 2015 | 07:34 AM
Tonyz400's Avatar
Yeah mines a garage queen, but I think I'm gonna go the way of external tint. I think it will help out the look. Like Sparky said, as long as it isn't just that orange (even though technically orange and blue are complimentary on the color wheel...I went to art school. Had to come out learning something, right?)
Old Feb 14, 2015 | 06:51 PM
ReFtheMC's Avatar
After going through a couple of aftermarket sets I've settled for VHT'd Stock corners. No more leaks and cracks from daily use
