98 trans am cluster/interior led upgrade help
Hello, I have a 1998 trans am and want to upgrade the dash/interior to leds.
I have the 6le designs overlay also. I read all the posts and saw the bulb list this is what I cam up with. I want to order only once from superleds.com.
Can someone verify if these are the correct bulbs to use for the bulb/led swap.
cluster........................WLED-CWHP5.......COOL WHITE
turn signal...................WLED-BHP5..........GREEN
high beam...................WLED-GHP5...........BLUE
shifter,door,hvac............74-CWHP3...........COOL WHITE
Dome............................RL4410-xhp9.......COOL WHITE
headlight switch................NEWO3-WHP......COOL WHITE
map light..........................4410-CW9.........COOL WHITE
>>can I use the bulbs for the map for the dome also?
Any help would be great thanks
John
John
