Sponsored by: DashLynx
***BLS 98-02 FIREBIRD Projector Headlight Kit SUMMER GP***
Old 06-28-2015, 06:16 AM
BLSolutions's Avatar
Talking ***BLS 98-02 FIREBIRD Projector Headlight Kit SUMMER GP***
***BLS 98+ Firebird Projector Headlight Retrofit SUMMER 2015 GROUP BUY - Budget (New!), V2, Premium and Premium Plus Kits Available!***
GP GOOD THROUGH July 12TH - Spots are limited!
We are pleased to offer the most powerful and best performing lighting system for 98+ Firebirds EVER available on the market. For this GP, we have added a new "Budget" kit option for those who want good lighting performance, but need to do this as cost effectively as possible.
BLS Kit Levels:
  • Budget - Pair of Hella Low Beam Projectors (used in former V1 kit), Mounting Plates, Adapter Connectors. You source a HID kit of your choosing or purchase a Morimoto HID kit from us.
  • V2 Standard - Our latest and greatest using Bi-Xenon Projectors providing both low and high beam HID output (replaces OE low beam components only). Includes Morimoto HID kit.
  • V2 Premium - Includes everything from the V2 but adds a pair of Hella High Beam Projectors to replace your OE high beam components.
  • V2 Premium Plus - What's better than one pair of bi-xenon projectors? Two pairs of course. Kit includes two pairs of bi-xenon projectors, all components for install and two Morimoto HID kits.
For our existing customers with the V1 kit:
- You can upgrade to the new system while retaining much of your existing BLS kit saving installation time and money. Those with premium systems can still retain their high beam projectors.
- Existing customers will re-utilize their clear main protective lenses, HID ballasts and relay wiring. New HID lamps and some additional wiring will be included with the upgrade setup.
- You must have your original, unmolested factory headlight buckets and hardware including the high tension spring. We can provide stainless hardware to secure the bucket trim ring if needed.
Stock - Low beam mode shown
BLS V2 Bi-Xenon Kit Performance:
DDM Tuning Ballasts / Morimoto 5000k Lamps – Low and High Beam
Morimoto HID system - 35W Ballasts / Morimoto 5000k Lamps – Low and High Beam - Shown on 67 Camaro and Jeep Wrangler - Both using the same projectors as this kit
Low Beam
High Beam
BLS V2 Bi-Xenon Kit Aesthetics – Courtesy of the Alchemist:
BLS V2 Premium Plus - Courtesy of WS6 What (Headlight shroud removed):
Installation:
Installation instructions will be emailed for each kit upon shipment and if you can install a new headlamp in your car, this will not be much harder. Simple hand tools are the only requirement and will be outlined in the instruction manual so you have just what you need.
Adjustment:
Since the V2 uses the low beam factory bucket, adjustment will be the same as stock. For those purchasing the premium kit with the high beam projectors, adjustment requires a little extra work. The factory top and side adjustments are retained however we include a third adjustment point where the factory spring resides replaced with stainless steel hardware.
Customer Pictures – These images utilize our V1 kit.
What You Get: Special Group Buy Pricing
*** If you do not have unmodified, low beam headlight buckets, the V2 kit will not work***
NEW Budget Kit - $175 shipped - NO HID KIT INCLUDED (PM us for international shipping charges)
- Hella Low Beam Projectors
- CNC Machined Projector Mounting Plates
- Adapter wiring/Stainless Hardware
- Instruction guide (Emailed PDF)
- Morimoto Complete HID kit (add $150)
Existing Customer Upgrade: $250 shipped - **Must have existing, unmodified low beam buckets** - (PM us for international shipping charges)
- Morimoto Mini D2S Bi-Xenon Projectors
- Morimoto HID Lamps – Specify (4500k, 5000k, or 6000k)
- CNC Machined Projector Retainer
- Split connector wiring
- Sealant
- Detailed Instruction Guide (Emailed PDF)
Standard V2 Bi-xenon - $525 shipped (PM us for international shipping charges)
- Main Protective Cover Lenses
- 35W Morimoto Ballasts
- Upgraded HID Relay Harness with Plug-N-Play Connectors
- Sealant
Premium Kit: Low & High Beams - $795 shipped (PM us for international shipping charges)
- Morimoto Mini D2S Bi-Xenon Projectors – Low Beams
- Hella DOT/SAE 60mm Projector High Beams – Halogen Lamps
- 35W or 50W Morimoto HID Kit (DDM Slim HID Kit – subtract $70)
- Aluminum Mounting Frames – High Beams Only
- Acrylic Hardware Cover – High Beams Only
- 65W Halogen lamps w/ PnP connectors (Different lamps available at slight additional cost) – High Beams Only
- Stainless Hardware – High Beams Only
- Sealant
Premium PLUS Kit: Low & High Beams - $945 shipped (PM us for international shipping charges)
- Morimoto Mini D2S Bi-Xenon Projectors – Low & High Beams
- (2) Pairs of Morimoto HID Lamps – Specify (4500k, 5000k, or 6000k)
- (2) 35W or 50W Morimoto HID Kits (DDM Slim HID Kit – subtract $140)
- (2) Upgraded HID Relay Harness with Plug-N-Play Connectors
- Sealant
HID Color Options (Low Beam Only)
4500K – White with slight hint of yellow
5000K – Bright White with touch of blue at the cutoff - Standard and most popular
6000K – White with Blue Tint
Halogen Options (High Beam Only)
Optional Lamp Choices - Extra Charge Applies (Kit will include standard halogen lamps)
Yellow All Weather - 55W - $40
Ultra White - 55W - $30
Pure Blue - 65W - $40
Titanium White - 65W - $55
Group Buy Info:
The Group Buy will last through July 12th or until we receive at least 10 orders. Construction time is 3-4 weeks.
If you would like to purchase the BLS kit, please PM me with the title "I WANT THE BLS KIT" and we will send you the payment information.
Old 07-02-2015, 12:13 PM
ThoR294's Avatar
bump for super awesome non ricer headlights!
Old 07-03-2015, 05:40 AM
Thanks for the bump!
All PMs returned and thank you to those who have already ordered! A little over one week to go. We hope everyone has a great 4th!
Old 07-11-2015, 06:16 AM
All PM's returned! Last weekend for the GP!
Quick Reply: ***BLS 98-02 FIREBIRD Projector Headlight Kit SUMMER GP***
