Mini H1 Projector Cutoff Issue
Old Jul 19, 2015 | 07:15 AM
Blackbirdws6's Avatar
The hot spot is better with the Morimoto by a significant amount however it should be over more towards the step a touch. Sucks the lens is causing the issue.
Old Jul 19, 2015 | 01:07 PM
SparkyJJO's Avatar
Interesting. I've not seen that happen before and I have two retrofits.
Old Jul 19, 2015 | 02:15 PM
DopeFedZ's Avatar
Yeah I think its kinda strange especially when these lens came off another headlight that uses a projector on it.
Not going to worry about it though I have 10x better lighting now with this compared to the stock headlights and the projector ebay headlights.
Old Jul 20, 2015 | 10:30 AM
sweetbmxrider's Avatar
Were those shots in the housing without the lens? I know chrome can reflect a lot of light and doubt it would cause the double cut off, just spit ballin.
Old Jul 20, 2015 | 08:35 PM
DopeFedZ's Avatar
Yeah they were in the housing but I wrapped the projector and filled the housings with a couple rags to cancel that possibility.
Old Jul 24, 2015 | 12:25 AM
omarrakeen's Avatar
so problem wasnt solved? if everything fails try plexi glassing a headlight cover, it kills me to see the cutoff lines distorted/unmatched my OCD kicks in and it does weird things am about to order those generic morimotos install them in my high beams and run 4 projectors soon. what bulb/ballast are you using?
