How to Remove the Rear Spoiler????
Old Sep 2, 2015 | 08:14 AM
jordanf1986's Avatar
Default How to Remove the Rear Spoiler????
I just got an OEM SS Spoiler for my 02 Z28, Ive never removed one before. It may be a stupid question but i wanted to ask so i wouldnt screw either spoiler up lol. Thanks in advance.
Old Sep 2, 2015 | 10:04 AM
TechCam97's Avatar
Open your rear hatch and pull off the plastic inner trim piece. There are four (I believe. Might be six) nuts, just remove them and then disconnect the third brake light connector on the driver side. After that, lower the hatch until it locks. Pull up gently, but firmly, on the oem spoiler and it will pop off. Install is reverse of removal.
Old Sep 2, 2015 | 10:32 AM
Awesome thanks I didnt notice any nuts, are they under the black caps?
Old Sep 2, 2015 | 02:03 PM
jaxcam02's Avatar
Yes. I like to use a long wide flat putty knife or equivalent metal piece to pry the plastic shroud away from the bottom of the hatch. You may not feel comfortable with the amount of pressure needed to remove it but just pull it and it will come off.
Old Sep 3, 2015 | 12:03 AM
crimson_bird's Avatar
FYI the 3 piece is not really something you remove unless you are planning to have some body work done at the same time.. You're going to have holes in your quarter panels.
Old Sep 3, 2015 | 08:58 AM
Awesome, thanks for the input guys, im just going from a factory Z28 wing to a SS wing and wanted to get some details before i started taking it apart and messed something up
Old Sep 3, 2015 | 12:42 PM
jaxcam02's Avatar
If your adding the SS spoiler make sure you pick up some 3m double sided automotive tape and cut to size of the SS posts to tape them to the spoiler and hatch so the posts won't rub the paint off the hatch
Old Sep 3, 2015 | 02:06 PM
Oh thanks for that, i never even thought about it.
Old Sep 3, 2015 | 02:34 PM
jaxcam02's Avatar
What I would do after cutting the tape to the the size of the post is to go ahead and prefit the spoiler on and bolt it down, then get some thin masking tape and mark the edges of the area the posts cover. Then remove the spoiler, peel off one side of the 3M tape for the posts and attach it to the hatch within the area you have marked by the masking tape. Then just before installing the spoiler for good peel the other half of the double sided tape off and place the spoiler in place.
Old Sep 3, 2015 | 03:56 PM
2JAWZ's Avatar
^^Good to know tip right there*
