construction of new style daytime running lights??
Old Oct 14, 2015 | 06:23 PM
jlcustomz's Avatar
Default construction of new style daytime running lights??
Looking into converting my almost 6 year old 2010 Camaro nose el camino conversion to a 2016 like look.
I handmade my previous headlight assemblies, since new versions were over $800 ea at the time, plus harness, ballast etc. I'm sure the 2016 Camaro light will cost even more, so trying to figure out how to make my own modern drl parts. I know it's probably a COB led design. I did see 7" continuous look drls I could use for the lower fascia & some slightly flexible units, but not quite what I think I may need. New subject to me.
Any advice would be appreciated.
2016 Camaro headlight.
Old Oct 14, 2015 | 07:06 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Cool, good luck.
Old Oct 15, 2015 | 02:31 PM
omarrakeen's Avatar
IMO i wouldnt bother with DRLs just use a COB halos as your DRL some come with RGB LEDs so that they can be DRL or just halos. does it have a halogen reflector or HID?
Old Oct 15, 2015 | 03:30 PM
jlcustomz's Avatar
This is what I need to see lit up, sort of a bent L shape, not a round halo.
My existing handmade assemblies, using halogen bulb with the thick glass lens. Never did install lights in my round halo, really wanted it just to have the eyeball look.
Old Oct 16, 2015 | 08:20 AM
omarrakeen's Avatar
I doubt they'd look the same because the '16 housing is wider than your current housing. there are flexible strips that give off a uniform light (not individual bulbs) but i have never seen them in person you could give that a shot.
Old Oct 16, 2015 | 04:26 PM
jlcustomz's Avatar
Yea, I know I'll have to extend or remake my housings.
Been doing some general google searches. Besides the odd places, JDM toystore lists what they call a switchback strip, 24"long , .32 thick, $69.99 pr. Switchback means they can be wired to turn signals to flash amber.
Superbrite leds.com lists evenglow rope lights in 12 & 24" lengths for 12.95 & 19.95 each.
Either could simulate the look from a distance, but the factory light has some depth to it.
Something else interesting I did see was an ad for bmw I-8 laserlites. I could easily make the look of the factory part from clear lexan or acrylic, But it would take more than a few white leds at each end to achieve enough briteness. Ever see 12 volt white laser lights??
May need to do some experimenting.
