Sponsored by: DashLynx
Has anyone tucked the wire harness that crosses the engine bay?
Old 10-01-2015, 05:00 PM
RebelExtrm02's Avatar
Default Has anyone tucked the wire harness that crosses the engine bay?
There is a large harness loom that crosses the radiator core support under the airbox in the front of the car from the drivers side to the passengers side. It looks like it could be ran behind instead of in front of the support, maybe between the condenser and radiator. I swear I've read on here that someone has tucked it that way before but I cannot for the life of me find the thread. Has anyone relocated this giant wire loom to clean up the front end a bit more? If so, how and do you have any pictures?
Old 10-02-2015, 02:27 PM
jmm98LS1's Avatar
I added about 2ft to that entire harness and ran it underneath the core support to get it out of the engine bay and mostly hidden. I had to move it to make room for pusher fans & stood up radiator.
Old 10-02-2015, 02:38 PM
blackbyrd's Avatar
I think you would have enough slack to take it behind and use the holders for the fans controls on the back of the fan shroud. never done it though, I dont even know whats in that harness. I know it has the washer fluid pump wire, but what else is in it? passenger side headlight motor?
Old 10-06-2015, 09:35 PM
Firebirdmuscle's Avatar
Ayou are referring to the fuse box harness. A few folks have moved it down where the air pump is from th factory and then made a cover plate with out extending the harness. I tried it this way at first and had lots of problems like this. I ended up extending all my wires and I moved the fuse boxes under the steering wheel and then routed the wires under the fender well down under the core support and the back under the passenger side fender well. It clears up the engine bay a whole lot and looks very good when you take the time and make the cover plate and paint everything. It's a very time consuming process. Make sure to take your time and work slow to make sure each wire is not pulled to tight or if you extend the harness make sure you solder the right ends back together.
Old 10-06-2015, 09:37 PM
https://ls1tech.com/forums/appearanc...elocation.html
https://ls1tech.com/forums/appearanc...s-updated.html
Old 10-07-2015, 06:20 AM
LPE 403's Avatar
I absolutely believe you can run it through the core support if you drill some clearance holes in the support large enough to clear harness plugs.
If youre not into that, you can always make it look a little better. I wrapped and secured it to the core support. Cleans up a little....
Old 10-07-2015, 10:11 AM
Correct, it has the harness for the passenger side headlight, horns, fog light, and a few other odds and ends. There is quite a bit of slack in it even when ran in the factory location across the front.
I never thought about going through the support. I'll have to look into that. I do have that same loom that you're running and it doesn't look bad at all. Decisions decisions.
Old 10-13-2015, 08:04 PM
HotWhipT/A's Avatar
I ran it almost like the factory, but instead of hanging it off the core support, its' hidden behind that black plastic cover. Only thing I wish I did was fill the holes where the bolts used to be. Maybe a future project of repainting the core support.
The following users liked this post:
bobcat52 (05-14-2020)
Old 10-15-2015, 11:29 AM
DaRReLL's Avatar
Sweet mother of gawd!! That engine is fantastic!! Even has a blue air filter....
Old 10-16-2015, 06:06 AM
01badbird's Avatar
very nice! there is some slack in it and mine is ran on the underside of support its hanging in first pic its from when I did my support. I also used a smaller diameter fabric wire covering to help hide but cover in second pic really helps hiding! Name:  bay2013_zps689d2e01.jpeg
Size:  90.3 KB Name:  092_zpsqxd1j8q4.jpg
Old 10-16-2015, 12:59 PM
blackbyrd's Avatar
That is one clean engine bay, where did you get the cover between the core support and bumper?
Old 10-16-2015, 05:03 PM
crimson_bird's Avatar
His two hands
Old 10-17-2015, 08:57 AM
01badbird's Avatar
Originally Posted by crimson_bird
His two hands
I made it to help hide all that stuff and like your new project you have crimson bird!
Quick Reply: Has anyone tucked the wire harness that crosses the engine bay?
