To Paint or not to Paint that is the ?
Old Jan 1, 2016 | 07:14 PM
madmike9396's Avatar
Default To Paint or not to Paint that is the ?
My cowl around where the windshield wipers are is fading.(the black plastic ) Is there a way to bring this back to life ?
Or can this be painted to stay nice looking?
Thanks to anyone with advice
Old Jan 1, 2016 | 07:17 PM
Turbo LS1 SS's Avatar
Use SEM trim black. It sprays out nice and even - I did this on my last car.
Old Jan 1, 2016 | 07:19 PM
Awesome ! I will look into that
thank you
Old Jan 1, 2016 | 07:22 PM
G-X-P's Avatar
"Back to black" works good but don't use it if you might want to paint it.
Old Jan 2, 2016 | 12:52 AM
SteenH's Avatar
Yep works well. The silicone in it will make it a nightmare in the future if you want to paint it!
Old Jan 2, 2016 | 07:37 AM
Thanks guys
Old Jan 2, 2016 | 07:39 AM
Will this stay on or just fade again in a few days ?
Old Jan 4, 2016 | 02:14 PM
Unertl42's Avatar
It will last a little while, how well is paint going to stick though, and it will look way worse if it starts pealing off
Old Jan 4, 2016 | 02:33 PM
That is true
Old Jan 4, 2016 | 03:09 PM
arjanrdc's Avatar
Trim restorer such as GTechniq would bring life back into the trim for quite a while. But it is costly.
Old Jan 4, 2016 | 07:33 PM
Thanks I will look into that as well
Old Jan 4, 2016 | 07:52 PM
98CayenneT/A's Avatar
What about black plasti dip...... Lame? I think it might look good
Old Jan 4, 2016 | 08:03 PM
That has also ran through my mind as well
Old Jan 5, 2016 | 10:30 AM
arjanrdc's Avatar
If you do decide to plastic dip it or spray paint it. Make sure all traces of tire/trim shine are removed first. Isopropyl alcohol diluted should be able to make sure the trim is clean and free of contaminants
Old Jan 5, 2016 | 04:11 PM
RebelExtrm02's Avatar
Just grab a can of satin black krylon fusion. I painted mine after I couldn't get the rustoleum "restore black" plastic dye to have an even enough look. A couple light coats of the satin krylon fusion and it looks like fresh plastic. It was over a year since I used the restore black and I rubbed it down really good with some wax and grease remover before painting.
Old Jan 5, 2016 | 05:24 PM
Thanks for the replys guys
Old Jan 6, 2016 | 12:56 PM
The Guz's Avatar
Look into solution finish.
Old Jan 7, 2016 | 10:40 AM
sweetbmxrider's Avatar
Definitely paint it, just scuff it before hand and wipe it down. Prep is what makes a paint job stick.
Old Jan 18, 2016 | 11:25 PM
Zlow28's Avatar
how bad does it look OP?
Mine looked pretty faded a first, but I started using VRT dressing from adams polishes whenever I wash the car. It comes out looking really good and stays on for a good while. I also use it on other plastics trims on my truck and it really works wonders.
Old Feb 7, 2016 | 02:40 AM
The Guz's Avatar
Here's another option. I just received this product to review.
https://ls1tech.com/forums/appearanc...l#post19139458
