98 T/A Headlights
BLS (Blackbird Lighting Solutions) is a sponsor and has some projector kits. Otherwise, you can assemble your own custom setup.
Please don't put HIDs in Halogen Reflector Housings. They won't spread the light properly.
You have 3 main avenues:
1) LMC Halogen Reflector Housings with Halogen Bulbs (use 9011/9012 bulbs which are brighter than 9005/9006 and fit the same housing)
2) BLS Projector Kit
3) Make your own setup.
I made my own setup because neither of the other options existed at the time. However, I've accumulated parts for a better setup using HID projectors from a G37. Its just a pile of parts right now though.
Fog Lights
There are a few different options here. I've tried the Pilot/CyberWhite aftermarket set, but the beam pattern was wrong for a fog light. More recently, I installed Morimoto LED Housings that were originally intended for a F150. I made my own brackets to fit them.
I think BLS was working on a bracket for a different Morimoto LED Housing.
More Info
Check out the Lighting FAQ for more information on Headlights and Fog Lights.
https://ls1tech.com/forums/appearanc...hting-faq.html
