Clear turn signal lenses?
Wow, I've had clear lenses for years and never had the issues these guys are having. Always bought them on ebay, had them on every one of 5 Camaros. I will say, black housings popped bulbs like popcorn. Clear? Never had a problem. Get them for the lowest price you can find, its not like one place makes them special or anything.
I have the clear lenses on my car. I'm on the second set as the first blew the bulbs and melted the housing. Second set did it once and I figured out the problem. After time the gasket on the light socket shrinks and doesn't seal as well. I got a replacement socket, swapped the gasket to the original on the car, and all my problems went away. I'm planning on replacing them again because they haze, but that's it. I use amber bulbs in the front and I'm going to test some LED's in the rear clear markers when I have time to get to it.
OK here's my experience.
Most of the corners you find on ebay are crap and will melt, deform, let water in, and pop bulbs (and fog up). Been there, done that.
Only ones that seem to last longer and not have these issues so bad are made by Depo I'm pretty sure, as they use a different plastic and have a metal heat shield in them just like OEM ones that prevent the bulb heat from cooking the plastic. Ebay seller neondials had them last I checked.
#33
They OEM bulb seals get squashed when putting the plug in the hole. The bulb is located to close to the housing. The bulb melts a hole in the back of the housing. Water seeps in through the hole for the bulb. Water seeps in through the hole created by the bulb. The bulb blows every month. What more do you need?
#35
To the OP don't get butt hurt there are a bunch of azzholes around here.
