Cracked dash
To do it:
- remove the A-Pillars from both sides (phillips head screwdriver)
- use a plastic trim-wedging tool to slide under the front of the dash and firmly pry UPWARD while holding the rest of the dash down and restricting as much other movement as possible..
--one just infront of the passenger side airbag
--one just to the right of the Window Defroster Vent / Alarm Light / light sensor
--one just to the LEFT of the Window Defroster Vent
--one directly infront of the steering wheel.
- the front of it will move back the back of it near the windshield will be velcro'd down, gently and ever so easily and evenly move the dashboard toward yourself to break the grip of the velcro
- you will be forced to SLIGHTLY bend ONE SIDE of the dashboard away from the A-Frame to clear the A-Frame, more than likely if you managed to keep it in one piece to this point, its definitely going to crack here...
I personally wouldn't bother. I replaced mine with a brand new GM unit for about $500 - but I only went that route because the eBay one simply put would not fit in my car and left me completely without a dash so I had no other choice. If you're feeling confident you can get away with an eBay dash for about $280 - 300ish.. but you will likely have to modify the tabs that snap on to get it to work, and Velcro did not work for my case.
Otherwise, you can use a dashcap or dashmat.
Good luck.
