Ceramic Coating
From what I have used
Optimum Gloss Coat -
I am 50/50 on this one. What I mean by that is the performance and longevity claims of it. Optimum claims it will last 2 years and that it is a 3 year coating. Well on my uncles car that I applied it to, it failed sooner than the 2 year claim. There was nothing left on the paint.
On my dad's it seems to be holding up ok.
Optimum states it does not require a topper/rejuvenation type product and I have to disagree based on the results I have seen.
Ease of application is super easy. I would highly recommend using optimum hyper polish with this one as if it does fail early then optimum blames the polish used.
Sonax CC36 Ceramic Coating -
This is new for 2017. I was sent this one by the folks at Autogeek. It is a 2 part aerosol coating (base coat + gloss coat) applied with the provided applicators in the kit.
Application is easy. Aggressive water beading and sheeting. One of the best I have seen. It does feel a little less slick than some of the other coatings.
For a larger vehicle one would need two kits and the cost is up there. Best to get it when on sale. I will say the aggressive water behavior is impressive.
Cquartz TiO2 -
This one is pretty good. I had coated a little area with some and it did well. It was not a large enough area for me to say it is better than any of the others.
I recently coated my front bumper with this and it went on easy. Just as easy as gloss coat.
Cquartz UK -
I have recently coated my front bumper with this and it does not need a lot of time for it to be removed. It is a tiny bit more finicky than TiO2 but in the end it went on relatively easy.
What I have done is coated my front bumper on my daily driver with a base layer of cquartz UK + TiO2. What this does is that UK forms a stronger base and TiO2 provides a more stain resistant top coat. This was recommended by Corey at CarPro. I will be using this combo on a full vehicle shortly.
I would also consider using CarPro Essence as a primer polish prior to Cquartz. Will add some great gloss and it does contain a little fillers to fill in the minor defects that one does not want to fully remove.
I will be maintaining with Reload and Ech2o which is a pretty nice maintenance regiment and adds amazing gloss.
I have heard good things about GTechniq Crystal Serum Light + Exo V3. I have some but I have not had the chance to use it. If it is like their wheel coating then it will be a very easy application. I have seen some great water behavior videos of this combo.
Pinnacle Black Label Diamond Paint Coating V2 -
This did fairly well when I used it. It was going strong at 20 months before I re-polished the car it was on. Very easy to apply and maintain.
Gyeon is one of the newer companies on the market and they have some real nice offerings. I have only used Can Coat which is sort of like an entry level coating. It has a stated durability of 6-9months. Really nice water behavior and easy to maintain with Cure. I would recommend using Gyeon primer polish with any of their coatings. It will add gloss.
I did not make it easy on you but I would consider GTechniq or Cquartz first over Gloss Coat. Gyeon Can Coat and Pinnacle Black Label are good for someone wanting to get their feet wet with coatings. Can't forget McKee's 37 coating.
I forgot to mention that it is a good idea to do a decontamination wash 1-2 times a year to keep the coating at it's maximum performance without getting clogged with above surface contaminants.
This was my red SS after about a year and half.
I need to place another major order of supplies, and the McKeey's 37 line of products has me intrigued. I've heard good things about it, so I'm thinking about giving their line a try. Anyone used their stuff? Were you happy? How did it compare to other brands you've used?
I also heard it is a rebrand coating.
With regards to McKee's they are a great product line. I personally know Nick who runs the show at McKee's. I have used some of their line and every product I have used worked just as described. There will be a new version of the McKee's coating coming out in the next few weeks.
I would consider the combo of Cquartz UK + TiO2 or GTechinq CSL + Exo V3.
If you go the cquartz route the UK + TiO2 is really good. Happy with it on the front bumper on my car.
Good graphic from GTechniq. I would recommend CSL + Exo V3. I will be trying this combo in a bit. Very impressive from the videos and photos.
