Detailers! Is this fixable?
** I had a plastic tarp over the car for years, and that could be a reason?
Clear is not a solid surface. A side view under a microscope reveals a sponge-like texture of the chemical structure. Like any other material, a paint system expands and contracts depending on temperature.
Take the tarp off and pull the car in the sun (I know... winter is not the best time for that.) Leave it there for 1-2 days. If the moisture is still there (which by the looks of it, it will be) then try an IPA (rubbing alcohol) soak. Then try polishing. If that fails to meet your approval... re-pspray is the solution.
Go ahead and paint correct it. If it is clear coat failure, you're going to have to repaint regardless, so the risk is irrelevant.
