Update 2: Project GTO shift knob
Old Jul 1, 2004 | 11:27 PM
StoleIt's Avatar
NKAWTG...N
Lightbulb Update 2: Project GTO shift ****
Well some good news some bad news. Good news: Picked up the manual GTO **** from the dealership, the boot is still back ordered. It is a solid huge peice, alot more than just the **** that I was expecting. I put the pro 5.0 in with the help of SilverGhost .
Bad news: GTO **** wont come off the stick its on. Atleast not with the effort SilverGhost and I tried (didnt want to break it). Even worse is their is bracket on the stick that would match perfectly up with the existing shifter. Screws right in using existing holes and bolts. BUT, the bracket is on a 45 degree angle and would look like crap.
For those with a stock shifter, the bracket fits on it, slides on like a glove. But you still have the 45 degree problem.
For those with most aftermarket (not sure but atleast on the pro 5.0) it wont fit. The pro 5.0 is too wide. I'm planning on taking either a dremmel or sawzal to the pro 5.0 and shaving a little of to get it to fit, but then the bracket problem still exists. So gotta find somebody with some metel work skillz to cut off the bracket and re-weld it on straight.
On a final note: WTF is up with the GTO trans? Is it on a 45 degree angle? Thats the only way the **** would then be straight on the car...crazy australians.
Old Jul 1, 2004 | 11:57 PM
01 Red WS6's Avatar
well shoot that **** has to come off some how, I may have to go and take a look at one
Old Jul 2, 2004 | 12:15 AM
HotRod68Camaro's Avatar
any way you could cut the welds on the tabs and rewled them in correct location?
Old Jul 2, 2004 | 12:28 AM
StoleIt's Avatar
NKAWTG...N
thats my plan! i just need to find somebody that can do that. also either the pro 5.0 requires cutting or more alterations to the gto ****...which i think i might do since any cutting of the pro 5.0 would kill resale value.
Old Jul 2, 2004 | 09:22 AM
black_z's Avatar
All of this for a shift ****.
Old Jul 2, 2004 | 11:03 AM
StoleIt's Avatar
NKAWTG...N
ya but it looks soo good
Old Jul 5, 2004 | 08:47 PM
PCG's Avatar
PCG
haha keep on it man, it will be worth it. Think you will be the first F-body with a GTO Shift ****.
Old Jul 6, 2004 | 12:03 AM
SNAKSLYR's Avatar
That shift ****'s been kicking your *** for some time now. Sweet mod though, love the way it looks. Bolt the stick onto the pro 5.0 and twist that **** off man, leverage. If you haven't tried already.
Will
Old Jul 6, 2004 | 02:31 PM
StoleIt's Avatar
NKAWTG...N
sadly the bracket on the stick is to small to hook directly up to the pro 5.0. And I have tried twisting it with a bunch of force but I don't want to use any more for fear of breaking something. If anyone knows how to pop the **** off that would be super, but it looks like I need to expand the bracket anyway so I'll just relocate the bracket.
Old Jul 7, 2004 | 10:44 PM
jonlee's Avatar
too bad neal... it should look kick *** though..
Old Jul 8, 2004 | 01:13 AM
StoleIt's Avatar
NKAWTG...N
omg jon ur still here! lol
Old Jul 8, 2004 | 03:51 AM
LS1MONSTER's Avatar
Talking
Duck tape the sum bitch if all else fails!! That is a nice **** though.. no pun intended!!
Old Jul 8, 2004 | 09:35 AM
joshs2000ss's Avatar
Do you think it's threaded on or is there a set screw hidden? Did you try to see if the threads were left handed instead of right?
Just throwing out some options.
Old Jul 8, 2004 | 06:03 PM
StoleIt's Avatar
NKAWTG...N
no threads, its one of those tricky pop on things. like you can get it on easy...but getting it off is a huge P.I.T.A.! I'm actually wondering if its defected with the ofset of 45 degrees...but either way i still gotta chop that bracket off and reweld it with a bigger gap...now just gotta find somebody with some welding skillz
Old Jul 8, 2004 | 11:30 PM
jonlee's Avatar
yep im back for july!
Old Sep 29, 2004 | 07:24 PM
Spurkey's Avatar
Lightbulb
We'll resurrect this one more time.... This guy figured out how to get the GTO **** off the shifter:
http://www.ls1gto.com/forums/showthread.php?t=1648
If you scroll down to post #2 and look at the 6th and 7th pictures in that post you'll see the stick without the ****, and the plastic piece inside the ****. According to him the **** fitting is similar to one found on a fuel line so if you can find a fuel line disconnect tool that'll fit around the shifter the **** should pop right off.
I tried to buy the shift lever and **** from a dealer in town, they said that the 2 together would cost me $414 CAN ( ~$325 USD). That's pretty ******* expensive for a leather **** stuck on a metal rod, I don't know if it's because the GTO isn't available in Canada or what. It's been asked before, what're the part numbers for the ****, lever, and boot? What do they cost in the States?
Old Sep 29, 2004 | 11:33 PM
01 Red WS6's Avatar
wow that awesome. part of the reason that I didn't do this already is price and the other was the **** not coming off the stick. I guess part of it is out of the way.
Old Sep 30, 2004 | 12:08 AM
StoleIt's Avatar
NKAWTG...N
Auto Shift ****, Red thread
GM# 392145646
Manual Shift Lever, Red thread (**** and stick are 1 unit)
GM# 92146323
Manual Boot, Red thread
GM# 92147889
Old Sep 30, 2004 | 12:10 AM
StoleIt's Avatar
NKAWTG...N
-the **** pops on and off, i just said screw it, im planning on cutting it off right above the thicker part filled with rubber then welding it back on straight or just then welding it to my LSS.
-it was extremely expensive. i also have the ****** auto shifter **** laying around and would be more than willing to sell it at a major loss because i have no use for it and the service department at jennings chevy is ******* retarded (thats why i have the stupid auto ****).
