Help removing cig socket from center console
Old Dec 29, 2017 | 03:07 PM
michaelhawk's Avatar
Default Help removing cig socket from center console
I found a good used one today, i wan to strip it down, clean and prep.
All messages i've searched and read explain how to push in 2 tabs from the inside to release the socket into 2 parts. This is great for the cig socket on the upper console by the TCS switch.
But the socket down by the brake handle & floor is different. It looks to be a solid piece, there arent any tabs i can see to disassemble it.
Old Dec 29, 2017 | 03:57 PM
Number Tew's Avatar
From the service manual, GM says you need to use J 42059 - a T-Shaped cigarette lighter removal tool.
Old Dec 29, 2017 | 04:39 PM
Thanks for the tip! In looking at that tool, it looks to be the one to release the version with 2 tabs.
This socket is different and doesn't have them. Pics of the inside and back attached
Attached Thumbnails Help removing cig socket from center console-img_0924.jpg   Help removing cig socket from center console-img_0925.jpg
Old Dec 29, 2017 | 09:48 PM
Number Tew's Avatar
Hmm, the service manual said it would have them. I will take a look and see if I can figure it out if no one else chimes in.
Old Dec 30, 2017 | 06:54 AM
Thanks for double checking...This socket is very different, the wires and connector being diff and it seems to be one solid part.
There are several vertical ridges that hold it in and tight against the plastic console. You can see some in the 2nd pic
Old Dec 30, 2017 | 03:35 PM
jrpimp00's Avatar
grab the threaded part and twist the outer body counter clock wise.
Old Dec 30, 2017 | 07:42 PM
That did it, Thanks!
Need to use a finger inside the socket to hold it while using a vice grip to twist that outer shell counterclockwise.
It's actually easy and clean to remove, once you know how!
