Cracked trans am door panels repair
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/966x1288/f9b059d9_36f2_4a28_a870_1ff8efafb44a_0b13902ef642f8c620487a97580ef16d67f85324.jpeg)
I bought pre-99 graphite door panels. Allegedly these do not crack due to being made from different plastic than 99-02 panels.
I cut the full moon tabs which hold the arm rest and map pocket. I then cut the half moon tabs which hold the cardboard backing. I used wire cutters and an exacto knife. A dremmel with a cut off wheel might work better.
I took the panels and backing to an upholstery shop for recovering. The panels were done in a stock leather type pattern material. The cardboard backing were done in the stock black perforated material.
I then ground down the half moons into rectangular posts to make it easier to reattach the cardboard backing. I epoxied the cardboard backing to these posts. It held in all but two places. So I re-inforced with aluminum tape.
I was told that permatex black plastic welder 5 minute set might have worked better.
Next I used screws and bolts to reattach the arm rest and map pocket.
I used small zip ties to reattach the window sweeps. I
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/1235x1233/57e9fc76_9342_4285_aada_29b331765b30_f4643eb4efb045d856cb7b63f1ed5333716ae60c.jpeg)
had to use a small drill bit to make the holes a little bigger.
Re-installed the insulation using contact cement and then put the door panels back on.
I also used gel krazy glue and epoxy to attach one of the hooks that was broken off.
The map pockets and arm rest were from a cracked ebony door panel.
Email me or PM me if you have any questions.
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20a8d4c2_f10f_4ea7_bc7e_7160a33f1066_dffc44150d6b0631cda34c9014b05685749c4918.jpeg)
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/e0a23764_56de_42d3_a784_cc5bd47a50d2_e0133f6561fd8bcf54c7dc24ebc4920c0abf0c6d.jpeg)
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/260d3ce6_8514_4fad_9ae3_30db0e118486_1e073375b3fd4d9d0b768179d3ed1380c4ac1e0d.jpeg)
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/1c68cc66_10a6_41a2_8195_966ee310b93f_5eaef01b9d1ade4ea8d0b87634fbd8f94f6b3c90.jpeg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/ca154289_e7d5_4b48_b443_2cdf853c9953_81e9a3a9d842109c2bf1bad7934e5961b9b48118.jpeg)
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/0d1cd811_4239_4a37_a1d9_969b0d01c319_0aab22ad60d54bfb305e7b8531fbc66521cd4bf8.jpeg)
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/88bf0de9_316f_407a_b180_fc14d89af6dc_be7494dfda46c4332ffb028b42aa0b2e37138d48.jpeg)
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/332a922f_a26e_4fa1_b654_194a87e3fba0_fef8169d5fd1490482c420e4134296041e102c35.jpeg)
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/dced621f_3d2f_476c_9b60_9094b5a4b18a_6039ccdee7277a85ae25d2cff4d51bff5cf25203.jpeg)
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x2000/f10ac66c_b73e_4d19_baed_f8584626e457_f393fc0e85c89f518a614e064db5cc443dab1064.jpeg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/1520x2000/35a6714f_785d_44d4_bf7f_df9e14297360_9a93d676413208892eb525aee5512d29c7bdfd0a.jpeg)
