Haze after DA polish
I use a Griots garage Boss 21 mm throw DA with the line of best of show Griots products. The paint was in good condition to begin with but I wanted level 10. The entire car looks great with exception of the passenger door which has some holograms/haze that I can't get rid of. I've tried going at it again with a finishing polish but for some reason it won't come out. I was hoping someone had a suggestion?
Thanks
I'll take a picture next time I see it.
seems like you might have missed a panel claying or some grit got in your pad or you accidentally used the wrong pad and compound combination. Can't say what exactly happened but starting again from the beginning should fix the problem.
I'm thinking your right.. might have to start fresh
To answer the question above.. it's a black 99 TA. I haven't seen the haze since because I haven't had the correct lighting.
I washed the entire car x2, clayed, washed again, blow dry, then started the compound process.
I used a heavier compound initially with microfiber pads, then followed up with the orange foam cutting pad, with a finer compound, then finished out with a yellow rupes pad with finishing polish, then black foam pad with finishing sealant and I've waxed the car a couple times in the last month and a half.
