CMX Spray Ceramic?
If you are interested in another alternative, Turtle Wax announced their new hybrid solutions ceramic line. I have not used any of their products but youtubers have started to post their videos about it. Apex Detailing for example has a video on their spray coating and polish & wax products that are designed to work together. They are intended to be user friendly.
One thing to keep in mind is that prepping the surface prior to polishing and protecting is key. I mean claying.
Are you planning to polish by hand or machine?
I'm looking for a durable, long lasting great shine - just about what anyone else would want. The car is black, so you know what that means. (I begged my wife not to buy a black car, to no avail). We try to avoid driving it in weather.
I've used Zaino, various "poly" products, and most recently gone back to Meguiar's #7 polish followed by #26 yellow wax. All of the above typically last me about six months.
I've clayed it in the past, but not in the last several times. I have Pinnacle and Zaino Fusion paint cleaners on hand and use a Porter Cable DA buffer.
I was thinking to perhaps do a round with paint cleaner, then #7, and then apply a ceramic finish if that makes sense.
Anything will last long though if a car spends its life in the garage.
One thing I forgot to mention is that it is recommended to do some sort of prep wipe post polish and prior to applying any type of coating product to remove any polishing oils. IPA has been used but it is not the greatest. Various manufactures offer a prep product such as CarPro Eraser. With that said M7 is not a good polish as it is heavy in oils which would not let the spray coating bond to its maximum. A paint cleaner is essentially a non-abrasive polish.
I also mentioned the new Turtle Wax Hybrid Solutions products. Check those out.
I got started today by cleaning the paint with the Zaino Fusion - a mildly abrasive polish - with a heavier cutting pad. It definitely left residue, so I'll follow up with IPA, or better product if I can find one locally. Then on to one of the Turtle Wax hybrids. That's the plan as of now.
the negative reviews are from people who didn’t bother reading the directions. If you spray it on the paint directly it will streak. If you follow directions on the bottle and spray it onto an applicator pad and rub it in. Let dry for 5 to 10 minutes and then wipe it off. It works perfectly. I washed my car today and it beaded up nicely. It was about two months ago I applied it last
I'm looking for something harder, clearer, and more repellent than the wax I've been using, which tends to get suffused with grime over time, white residue in seams and imperfections, etc.
It sounds like this product is almost as easy to use as spray detailer. If that's the case, and it only lasts 2-3 months, no big deal. Just re-apply.
A lot of the negative experiences happened to guys who sprayed it directly on the paint. Looking forward to getting to the application tomorrow morning! We shall see how it looks and how it holds up.
you make a good point. It doesn’t have that crap that builds up in crevices and no powder residue. Big plus in my opinion. And it’s super easy to apply. And doesn’t leave those waxy streaks. It wipes off really easy. Just make sure you let it dry for 5-10 minutes.
My take is that application is not quite as easy as detail spray, but as polishes and waxes go, quite easy. I found that hand application and removal was best. The directions say to rub it in until it disappears; it's sort of like applying Windex where you wipe until you don't see streaks anymore. Then when it's time to go over it, there's hardly anything to remove.
That's the CMX report so far. Durability is the only question now. I'll bring this one back when the finish starts to fail for a final report.
